1963 Coupe Antenna - NCRS Discussion Boards
1963 Coupe Antenna
  • Craig S.
    • February 19, 2010
    • 39
    1963 Coupe Antenna
    Was the antenna used for the base radio car a fixed mast or an adjustable mast. The car was built the third week of December 1962. Any help would be very much appreciated.
  • William C.
    • May 31, 1975
    • 6037
    Re: 1963 Coupe Antenna
    Manual adjustable mast. Early car should have a wonderbar radio without a surround around the outside edge of the hole.
    Bill Clupper #618
      • 15672
      ..as Bill said, but it didn't completely retract. The bottom section of the "telescope" is fixed.
      • Henry A.
        • May 31, 1990
        • 103
        Craig, welcome to the NCRS. You will be amazed at the knowledge base and helpfullnes of the membership. Enjoy the NCRS and your 63!
        Henry Atsma
        54 White/Red
        63 Red/Black SWC
        67 Elkhart Blue/Black BB Roadster
        91 Black/Red ZR1
        96 CE - LT4
        07 Red/Tan
        • Craig S.
          • February 19, 2010
          • 39
          Thank you for the reply. It does have the original Wonderbar radio. The antenna present at the time for disassembly for rebuild was a fixed mast antenna that appeared to be original, hence the question.
          • Loren L.
            • April 30, 1976
            • 4104
            Only VERY EARLY AMs (3500 or so) will not have the trim around the radio hole. Changeover to AM-FM O/A 13000.
              • 15672
              I believe later C2s had a fixed length antenna mast, so what you may have is a later GM replacement. Probably not to may 45+ year old cars have their original antenna.
              • Tom H.
                • December 1, 1993
                • 3440
                Duke is right. I believe 67 used a fixed mast. 63 to 66 was adjustable. Welcome to you and your 63. Always glad to have another 63 in the house !
                Tom Hendricks
                Proud Member NCRS #23758
                NCM Founding Member # 1143
                • John D.
                  • December 1, 1979
                  • 5507
                  Craig, In the old days Chevy sold an over the counter replacement antenna that was far from correct. It was way too high in every position. Extended or not.
                  Seems to be a lot of NOS ones on the market today that are correct in height. Maybe someone can chirp in here and tell you the correct measurements. JD
