Was the antenna used for the base radio car a fixed mast or an adjustable mast. The car was built the third week of December 1962. Any help would be very much appreciated.
1963 Coupe Antenna
Re: 1963 Coupe Antenna
Manual adjustable mast. Early car should have a wonderbar radio without a surround around the outside edge of the hole.Bill Clupper #618- Top
Craig, welcome to the NCRS. You will be amazed at the knowledge base and helpfullnes of the membership. Enjoy the NCRS and your 63!Henry Atsma
54 White/Red
63 Red/Black SWC
67 Elkhart Blue/Black BB Roadster
91 Black/Red ZR1
96 CE - LT4
07 Red/Tan- Top
Thank you for the reply. It does have the original Wonderbar radio. The antenna present at the time for disassembly for rebuild was a fixed mast antenna that appeared to be original, hence the question.- Top
I believe later C2s had a fixed length antenna mast, so what you may have is a later GM replacement. Probably not to may 45+ year old cars have their original antenna.
Duke- Top
Duke is right. I believe 67 used a fixed mast. 63 to 66 was adjustable. Welcome to you and your 63. Always glad to have another 63 in the house !
Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
Craig, In the old days Chevy sold an over the counter replacement antenna that was far from correct. It was way too high in every position. Extended or not.
Seems to be a lot of NOS ones on the market today that are correct in height. Maybe someone can chirp in here and tell you the correct measurements. JD- Top
