67 Crankshaft pulley - NCRS Discussion Boards
  • Mark P.
    • December 1, 2004
    • 62
    Re: 67 Crankshaft pulley
    I have a 67 base engine car that was equipped with the K19, AC and power steering. It has the dual groove crankshaft pulley and the add on pulley. The K19 was removed by a previous owner. All three grooves are used.
    Mark
      • 43222
      Mark
      Mark------
      Yes, and the 2 groove pulley should be of GM #3850838 and the 1 groove add-on pulley of GM #3751232.
      By the way, the GM #3850838 is long-since GM-discontinued. However, the GM #3751232 which was first used for some passenger car applications for the 1958 model year, is still available from GM 52 years after its original release!
        Originally posted by John Daly (19684)
        john
        Was that for all base engines ? What about if it had C60 and N40 ? Would it have the double pulley and then the add on ?.
        The AIM shows a car with C60,N40 and K19 has no less than 5 seperate fan belts !!
        thanks
        John -
        The base 300hp engine used the single-groove crank pulley only with or without power steering. C60 and/or K19 changed it.
