67 Crankshaft pulley - NCRS Discussion Boards
  • Joe D.
    • April 30, 2002
    • 382
    Looked at a 67 327-350hp car with power steering. The crankshaft pulley had 3 grooves. One was the alternator, second was the power steering and the groove closest to the fan was empty. Just wondering what the third grooive was for, a/c? Happy New Year. Thanks, Joe DeLuca
  • John D.
    • June 30, 1991
    • 875
    Re: 67 Crankshaft pulley
    joe,
    Just peeked at the AIM and it shows the center pulley location (#2) is for the A/C belt in cars with N40 and C60. Don't know if that's correct or not....
    jd
    • Patrick T.
      • September 30, 1999
      • 1286
      It's probably the "captive belt", which only goes around the crankshaft pulley and the water pump pulley. They are a PITA to put on. It's there in case your alternator belt breaks, you will still have a redundant belt to turn the water pump until you can make it to a garage to get fixed.
      So when are you picking up the car?
      • Joe R.
        • March 1, 2002
        • 1356
        If the car does not have AC, there should not be a third groove on the crank pulley. The third groove was only installed on cars with AC.
        If the crank pulley arrangement uses original GM parts, the third groove is actually a separate, add-on pulley that nests inside the 2-groove crank pulley. So, it is easy to remove.
          • 43248
          Joe and Joe------
          That's correct. If the car is an L-79, then the only way it should have had 3 belt tracks on the crankshaft pulley is if it also had C-60 and N-40.
          However, if the car is actually base engine car, then it would have 3 tracks if it had N-40 and regardless of other belt driven options. In the case of a base engine car, one of the tracks was used for a captive belt.
          As Joe R. stated, all C2 small blocks that had 3 tracks on the crankshaft pullies used a 1 groove pulley sandwiched onto a 2 groove pulley. No 3 groove crank pullies were ever originally used on C2 small blocks or, for that matter, C2 big blocks, either.
          • Gerard F.
            • June 30, 2004
            • 3806
            Joe,
            I've always thought that the 3rd groove of the crankshaft pulley on a 327, closest to the fan, was always for power steering.
            Jerry Fuccillo
            • Joe D.
              • April 30, 2002
              • 382
              The owner emailed me this morning and said it was for the a.i.r.??? He said there was bracket on the engine for the a i r when he first bought the car. I thought it would run on the pulley with the alternator? Happy New Year, Joe DeLuca
                • 43248
                Joe-----
                The owner is mistaken. The air injection reactor pump for all 1967 Corvettes equipped with K-19 was driven from the waterpump pulley set. In no configuration did it involve a belt which also encompassed any crank pulley. So, any 3 groove crankshaft pulley configuration was in no way related to AIR.
                • Joe D.
                  • April 30, 2002
                  • 382
                  Thanks Joe. I am still confused about the 3rd groove on the pulley. I am not sure if the car came with it or the original was replaced with it. I do not know if it's that big of a deal.
                    • 43248
                    Joe------
                    The part number on the pulley or pullies would be helpful in figuring this one out.
                    If the crankshaft pulley set-up is original to the car, it might be very significant. It could be the "clue" that indicates the car is/was actually a 300 hp that's been converted or "passed off" as an L-79.
                      Joe------
                      Also the presence/absence of a balancer bolt - the 350hp crank snout was drilled/tapped and used the bolt, and the 300hp crank wasn't drilled and used a press-on balancer.
                      • Joe D.
                        • April 30, 2002
                        • 382
                        Joe, Did the base engines use a 3 groove pulley?
                          Nope. The 300hp engine used a single-groove crank pulley - if it had power steering, it got the "add-on" single-groove pulley to drive the pump.
                          • Lawrence S.
                            • April 1, 1993
                            • 803
                            My original 67 L-79 with N60 only has two grooves on the crankshaft pulley.
                            • John D.
                              • June 30, 1991
                              • 875
                              john
                              Was that for all base engines ? What about if it had C60 and N40 ? Would it have the double pulley and then the add on ?.
                              The AIM shows a car with C60,N40 and K19 has no less than 5 seperate fan belts !!
                              thanks
