1969-70 smog pump question - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 876
    Can someone post an example picture of the date code on a smog pump for this era? Thanks
  • Jamie F.
    • May 20, 2008
    • 337
    Re: 1969-70 smog pump question
    Here you go...
    The date code is stamped on the bottom of the pump when mounted. Judges will check the date with a mirror. This one reads 28091S. Which is a Julian date code for the 280th day of 1969, or October 7th 1969. It is on a November 20th Trim Tag car. The 1 is the shift number and the S is a broadcast code. </SPAN>
    • Stephen B.
      • April 1, 1988
      • 876
      Thanks. I'm trying to compare font and such with a pump I purchased.
      • Kenny C.
        • March 2, 2009
        • 191
        Stephen
        If you need information or a system Bill Hodel is the guy you need to speak with. He advertises in the Drive Line. I purchased a complete system from him recently and its perfect. He was very nice and extremely knowledgeable.
        • Dale C.
          • November 1, 1999
          • 844
          I don't know for sure but I have been told that there is a difference in where this date is stamped. Like on my pump for a 68 its up on the boss and not down in the milled portion. Does anyone know about this minutiae? This is a Hodel pump.
          • Jack C.
            • September 30, 1992
            • 1090
            Dale, my original early 68 has it not on the boss area like your picture.
            Jack Corso
            1972 Elkhart Green LT-1 Coupe 43,200 miles
            Top Flight 1994, 2018 & 2021
              • 15601
              I have judges quite a number of 1968s witht he date on the cast part of the housing. I believe that is common for that style of pump.
              • Stephen B.
                • April 1, 1988
                • 876
                Thanks for everyone's help. Please submit some more pictures if you like so I can check fonts.
                • Mark D.
                  • June 30, 1988
                  • 2151
                  This pump is from Bill Hodel...
                  Kramden
                  • Stephen B.
                    • April 1, 1988
                    • 876
                    thanks for the pictures.
