Power brake hose clamps, what color green? - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1326
    Can I just use some of my left over green self-etching primer (similar to bird cage green) for the hose clamps on my power brake tube that runs from the booster to the intake manifold?
    Or do I have to buy a special can of paint for $5 to get my 1 finish point back because my clamps are black.
    Chris Enstrom
    2011 Z06, red/red
  • Michael H.
    • January 29, 2008
    • 7477
    Re: Power brake hose clamps, what color green?
    I thought the PB hose clamps were supposed to be black? I never seem to be able to remember which is which as far as fuel line clamps and PB hose clamps. (some sort of a mental block, I suppose)
    The fuel line clamps on my 66 are green. (different size than the clamp for PB)
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1463
      Hi Chris
      Save your "Bird Cage Green"
      Maybe someone can jump in with a better description, as the original Green you need was darker, more of an "Olive Drab" shade.
      HaND
      • Chris E.
        • November 3, 2006
        • 1326
        Originally posted by Mike Murray (25129)
        Hi Chris
        HaND
        That's kind of what I remembered as well, just wanted to get the groups' opinion on it.
        Chris Enstrom
        2011 Z06, red/red
        • Michael H.
          • January 29, 2008
          • 7477
          Are youse guys sure the power brake hose clamps are supposed to be green?
          • Chris E.
            • November 3, 2006
            • 1326
            I think the TIM/JG says they should be, so I got dinged in judging for it.
            Chris Enstrom
            2011 Z06, red/red
            • Michael H.
              • January 29, 2008
              • 7477
              I think I'd do a little research before I put green clamps on the power brake booster hose.
              • Chris E.
                • November 3, 2006
                • 1326
                Agreed, and this post is my version of research.
                Since the AIM doesn't really talk much about finish of parts, I'm posting here.
                Plus, there is the "well, that's what the book says" rebuke from the judges when I try and present a counter-argument. I figure for the hose clamps I can easily change it back and forth, and frankly once I'm done judging, I won't care about the color.
                I'm going for Duntov, and I need as few "little issues" like this as possible.
                Chris Enstrom
                2011 Z06, red/red
                  • 6942
                  Chris, my 72 p/b car has its orig, clamps and there black, I think the green were for the fuel lines and pcv valve. sorry I relealize your car was a 67 , that may make a difference-opps
                  • Dick W.
                    • 10483
                    From memory, me thinkee no greenie clamps on booster
                    Dick Whittington
                    • William S.
                      • June 28, 2009
                      • 28
                      Original 67 with black clamps.
                      Bill
                      • Brian M.
                        • February 1, 1997
                        • 1839
                        I'm for leaving them alone, aren't they the same as the PCV clamps?
                          Nope - the power brake vacuum hose is the only usage on the whole car for the #3829056 clamp - the PCV hose used #3829058.
                            • 11644
                            What'd you do - look it up in some database?
                            • Michael H.
                              • January 29, 2008
                              • 7477
                              Yup, and the 3829056 is black while the 3829058 is ugly green. The size is different for different size hose OD.
                              Pic of NOS of each size below.
