Power brake hose clamps, what color green? - NCRS Discussion Boards
    Re: Power brake hose clamps, what color green?
    What'd you do - look it up in some database?
    Naw...I keep all that stuff in my head.
      • 11668
      LOL!
      If I look around here... yah, I've got that same "file."
      • Chris E.
        • November 3, 2006
        • 1335
        #18
        Originally posted by Michael Hanson (4067)
        Yup, and the 3829056 is black while the 3829058 is ugly green. The size is different for different size hose OD.
        Pic of NOS of each size below.
        AHAH! See, I knew the answer was out there somewhere as to why I was nailed for 1 point in judging for having the wrong color clamps on my brake booster hose......
        Thanks guys.
        Chris Enstrom
        2011 Z06, red/red
        • Michael H.
          • January 29, 2008
          • 7477
          #19
          Thanks guys.
          So, if you already have black power brake booster hose clamps, yer all set. No green required. (unless you need it for other clamps)
          • Chris E.
            • November 3, 2006
            • 1335
            #20
            Ok, so now I'm really confused, because on page 79 of the 67 TIM/JG, it says about the PCV hose...."Two black phosphate spring tension-type clamps secure the hose."
            John said that the green part # clamp was for the PCV hose, and the black was for the brake booster hose, right?
            Chris Enstrom
            2011 Z06, red/red
            • Michael H.
              • January 29, 2008
              • 7477
              #21
              I don't have an AIM handy but I believe both the power brake hose and the PCV hose use the black clamps, part number 3829058.
              I think the green clamps are only used on the fuel line hose at the fuel pump and fuel tank sender.
              If someone here has a 64-67 AIM handy, maybe they can confirm the different clamp for the fuel line hose.
              • Mike M.
                Director Region V
                • August 31, 1994
                • 1463
                #22
                Very interesting
                Here we go again...
                The '67 and '65 JG make no mention of the clips, '66 says Green (Easily edited if necessary)
                Nice pics, weren't those clips with the square ends used in the shark years (Black) and became service replacements for the M-Y's?
                Keep 'em coming...
                HaND
                • Mike M.
                  Director Region V
                  • August 31, 1994
                  • 1463
                  #23
                  Ahaaa,
                  The '67 AIM confirms John's comments, 056 for the booster hose and 058 on the PCV hose .
                  The '66 AIM shows 058 for both.
                  HaND
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    #24
                    Originally posted by Mike Murray (25129)
                    Ahaaa,
                    HaND
                    What about the fuel line clamp?
                    • David S.
                      • August 9, 2009
                      • 595
                      #25
                      Don't know the part numbers but 66 fuel line clamps are green, and PCV are black.
                      -Dave
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        #26
                        -Dave
                        Yup, I think so too.
                        • Mike M.
                          Director Region V
                          • August 31, 1994
                          • 1463
                          #27
                          Curiouser and curiouser...
                          Both the '66 & '67 AIMs show the clips at the fuel pumps to be 3786276.
                          HaND
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            #28
                            HaND
                            Yup. The small green clamp.
                              • 15616
                              #29
                              Yes, the square ends are applicable for 1968 to around mid-1970s someplace. You will have to ask the 1973 and newer guys when the use of the square ends ended and the round -- "safety clamps" began.
                              FWIW: For 1968+: Black clamps for Power Brake vacuum hose
                              Green clamps for PCV
                              I realize that is not the subject of this thread, however.
                              • Chris E.
                                • November 3, 2006
                                • 1335
                                #30
                                Ok, so this brings up a really interesting question.
                                If I get dinged for a point like this on the judging field where the 6 or 7 of us here on the TDB are having trouble coming to a quick and conclusive answer, HOW DO I DEFEND MY POSITION ON THE JUDGING FIELD? Especially when the color of a part is not called out in the TIM/JG?
                                Again, I'm going for Duntov, and I know I'm going to get somewhere between a 9 and 22 point deduct at Regionals or Nationals. Since I can only afford to lose 135 points total, if I lose 22 on paint, I need to save every point where I can.
                                Chris Enstrom
                                2011 Z06, red/red
