Show Me Your Garage - NCRS Discussion Boards
Show Me Your Garage
  • Michael H.
    • January 29, 2008
    • 7477
    #31
    Re: Show Me Your Garage
    Originally posted by Jake Dykstra (7835)
    Mike--I see you have cleaned it up! I was hoping the '66 would be in better shape than that.
    Just a little dust. I'll run it through the automatic car wash next week.
    • Stewart A.
      • April 16, 2008
      • 1035
      #32
      Paul are they Vinyl tiles. I thought of using them do they wear very well and do oils come off easy ? Stewy
      • Bill O.
        • April 1, 2006
        • 542
        #33
        Four cars in a three-car garage. Sick.
        • Paul O.
          • August 31, 1990
          • 1716
          #34
          Stewart they are Vinyl tiles it's been about 9 years now and they are a little dirty not as bright white as new but oil clean up is no problem. Paul 18046
          • William L.
            • July 31, 1987
            • 39
            #35
            One thing I did with my garage that I don't see to offen is I carpetted the floor. I went to Home Depot and got enough indoor/outdoor carpet (dark grey) for $150. My garage is 720 sq ft (24 X 30) . It cleans easy and a pleasure to work on. Another thing I got was a vacuum that hangs on the wall with a 30 ft. hose. Good luck with your shop. Bill Lehmann
            • Michael A.
              • March 1, 1996
              • 507
              #36
              John
              I love the pay phone. I hope you have enough nickels, dimes, quarters or whatever to keep it fed!
              Cheers
              Mike Andresen
              Bloomington, IL
              • Stewart A.
                • April 16, 2008
                • 1035
                #37
                Paul, do you think they would whiten with a buff up or do they yellow over time ?
                • Paul O.
                  • August 31, 1990
                  • 1716
                  #38
                  Stewart never tried to buff them but they would probably clean up but not as good as new. Paul 18046
                  • Chris L.
                    • November 1, 1998
                    • 273
                    #39
                    I might have this photo stuff figured out now !! Try again..
                    • Stewart A.
                      • April 16, 2008
                      • 1035
                      #40
                      Chris well done you got the photos on there !!!
                      Chris is the floor the plastic lock system and how do you like it ? Stewy
                      • James O.
                        • November 1, 1985
                        • 160
                        #41
                        the use of go-jaks lets me fit 4 cars in a 3-car garage.
                        • Chris L.
                          • November 1, 1998
                          • 273
                          #42
                          Stewy...it's the locking type made by Racedeck. I had it down for 5 years now and never had a problem. It sounds a little "hollow" when you walk on it, but you get used to it. I think if I do another garage, I will go with the epoxy as it looks great when it shines and seems to hold up well. I'm into clean, shiny stuff!!. THanks
                          CHris
                          • Steven B.
                            • June 30, 1982
                            • 3990
                            #43
                            Stewy -
                            I had mine professionally done (www.homeprofloors.com) with the "Classic Floor" system. I let the slab cure for 4 months, and they steel shot-blasted it one day (2600 sq. ft.), poured the first coat the second day, and poured the tinted second coat the next day. Haven't touched it since.
                            The key to adhesion (in addition to the surface prep) is a dry slab, with no moisture migration from the underlying soil. I laid a 10-mil poly moisture barrier down first, then covered that with 5/8"-thick 4' x 8' sheets of high-density closed-cell foam with heavy foil on both sides, then poured the slab over that; great insulation (floor is warm and dry all the time), and zero moisture migration.
                            Temperature extremes here run from below zero in the winter to mid-90's (*F) in the summer, so it's heated and air-conditioned; have R-26 in the walls and R-58 in the ceiling (and the insulated slab), and two custom-made 18' x 8' steel/foam/steel insulated sectional doors with tubular seals between the sections. Insulation is EVERYTHING, and you can only do it right when you build it. My "retirement office" is out here too, and it's comfy year-round.
                            John, did you trip the ground so the phone works? I have one just like it.
                              Nope - it's strictly decorative - the real phone is behind the coffee mug.
                              • Bruce B.
                                • May 31, 1996
                                • 2930
                                #45
                                Here are a few pictures of my garage which I built 7 years ago. It is approx 26 by 37 feet and has a vaulted ceiling at the end where the lift is. It is super insulated and is heated by a hanging electric heater.
                                A great facility for working on my Corvettes.
                                I just completed my 57 250 HP FI, Powerglide car yesterday, time to go cruising.
