Lower Clutch Rod - NCRS Discussion Boards
Lower Clutch Rod
    • 43258
    Re: Lower Clutch Rod
    Originally posted by Rich Pasqualone (49858)
    I just thought I'd add that sometimes the wrong clutch fork ball/pivot studcan give fitts to the proper adjustment procedure. I don't have the dimentions off hand. If this was already said and I missed it sorry.
    Rich
    Rich-----
    Absolutely. 1955-81 Corvettes used only 2 different ball studs---1955-65 used a stud of 1-1/2" OL, 1966-E75 used a stud of 1-3/8" OL, and L75-81 went back to the 1-1/2" stud. Later in SERVICE, the 1-3/8" stud was discontinued and replaced by the 1-1/2" stud. As a practical matter, either of these studs can be used on any 1955-81 without creating too much in the way of problems and either could definitely be used on the 1966 model at issue here. The 1-1/2" stud, GM #3729000, was also used for for the most other Chevrolet applications and is VERY common. The 1-3/8" stud, GM #3887159, was Corvette-only.
    However, as you mention, if some other stud with a different overall length were installed, that would definitely "throw everything out of kilter".
