Hi,
After reading about the correct type of Lower Clutch Rod in the 1966 Judging Guide I looked at the one on my car and it does not look anything like it should. The one on my car is threaded and has a system that looks a lot like the upper clutch rod. So I ordered a correct replacement and when I went to install it, it was too long by 1/2 inch. There is not enough play between the clutch cross shaft and the clutch fork arm to get it to fit. Any ideas on what would cause this and are there any adjustments that can fix it?
Al
Al
