I need to replace a custom 1 leaf TRW spring on my 67 300hp. I found some old original 9 leaf ones. Question: do these wear out (other than the spacers) and how can I tell if it is usable and correct? Thank you, Bob
					Need advice on 9 leaf springs for 67 Vette standard
Re: Need advice on 9 leaf springs for 67 Vette standard
No, springs don't wear out. Neither do bridges, but what kills both is corrosion. If the leaves don't show signs of serious corrosion it should be good to go with a cleanup, new liners and spring link bolt cushions.
Duke- Top
Bob -- as for arch, member Gary Beaupre wrote an article in the RESTORER a year or so ago, giving measurements to take when C2 9-leaf spring on the bench. I used them a year ago when checking an original replacement. Can look in my notes if you can't access Gary's article.- Top
