Need advice on 9 leaf springs for 67 Vette standard - NCRS Discussion Boards
  • Bob H.
    Infrequent User
    • February 1, 1989
    • 11
    I need to replace a custom 1 leaf TRW spring on my 67 300hp. I found some old original 9 leaf ones. Question: do these wear out (other than the spacers) and how can I tell if it is usable and correct? Thank you, Bob
  • Lorne G.
    • June 30, 1988
    • 118
    Re: Need advice on 9 leaf springs for 67 Vette standard
    Hi Bob,
    Perhaps a good spring shop could tell you if the springs are up to par or in need of repair or re-arching.
    Lorne
      • 15667
      No, springs don't wear out. Neither do bridges, but what kills both is corrosion. If the leaves don't show signs of serious corrosion it should be good to go with a cleanup, new liners and spring link bolt cushions.
      • Bob H.
        Infrequent User
        • February 1, 1989
        • 11
        that's what I needed, thanks. Bob
        • Wayne M.
          • March 1, 1980
          • 6414
          Bob -- as for arch, member Gary Beaupre wrote an article in the RESTORER a year or so ago, giving measurements to take when C2 9-leaf spring on the bench. I used them a year ago when checking an original replacement. Can look in my notes if you can't access Gary's article.
