corect 1970 dupont paint code needed. Corvette Brz - NCRS Discussion Boards
  • Jon H.
    • January 1, 1999
    • 150
    I am refinishing my 1970 LT-1 convertible and it is originally code 993 Corvette Bronze. The body shop is telling me the Dupont code is 5128 and I have an old paint cross refference sheet that says it was Dupont code 4910. Does anyone know the difference between the two codes or can anyone point me in the right direct. thanks for your help.
  • Kent K.
    • December 1, 1982
    • 1139
    PPG code 2264 C'vette Bronzr Poly *NM*
    Kent
    NCM Founder - Member #718
    • Kent K.
      • December 1, 1982
      • 1139
      Kent
      • Larry M.
        • January 1, 1992
        • 2701
        Re: corect 1970 dupont paint code needed. Corvette
        Jonathan:
        According to the Corvette Auto Paint Conversion Chart from CORVETTECOLOR, the correct Dupont Code is 5128.
        See www.corvettepaintcodes.com
        Probably best to buy a small amount and have the shop shoot a test panel for you.
        Larry
        • Larry M.
          • January 1, 1992
          • 2701
          Jonathan:
          Larry
          • Dick W.
            • 10483
            If this is like most offset colors it will be way off in color and flake size. Hope you have a place that still has the original color on so that you may work with the new paint to get the tint right
            Dick Whittington
            • Dick W.
              • 10483
              Dick Whittington
              • Larry M.
                • January 1, 1992
                • 2701
                Jonathan:
                Additional research shows that Dupont Code #4910 is 1968 Corvette Bronze Metallic, OEM Code #992. I do not know how the 1968 and the 1970 bronze colors compare.
                As Dick Whittington points out, correct metallic particle size and tint can (will) still be a problem, even with the correct codes.
                Larry
                • Larry M.
                  • January 1, 1992
                  • 2701
                  Jonathan:
                  Larry
                  • Jon H.
                    • January 1, 1999
                    • 150
                    I guess my main question is: is there a difference between the colors on a 1968 vs 1970 Corvette Bronze?
                    • Jon H.
                      • January 1, 1999
                      • 150
                      • Jon H.
                        • January 1, 1999
                        • 150
                        • Jon H.
                          • January 1, 1999
                          • 150
                          • Dick W.
                            • 10483
                            YES
                            Dick Whittington
                            • Dick W.
                              • 10483
                              YES
                              Dick Whittington
