I’m attempting to repair my ‘65 headlight motors using an excellent tutorial by Alann Boatright. The motors are properly dated for my car, so I would like to keep them. I cleaned and removed the old grease and applied new grease. Both motor drive gears (the large pot metal gears) were significantly worn. I attempted to order new gears but they were on back order, so I rotated the original gears 180 degrees. The passenger side motor stalls when I install the gear train. The driver side motor has similar issues, but it will rotate the bucket slowly.
As a test, I removed the intermediate plastic gear and realized that the pot metal gear does not turn freely (by hand) after the housing fasteners are tightened. It is actually quite difficult to turn. As you can see in the photo, the gear housing cover (on the left in the first photo) is slightly warped. I’m not sure if this is causing the problem, or how I would find replacements (the covers are similarly warped on both the driver and passenger sides). I even tried two different used pot metal gears provided by a friend. I checked, and rechecked that I have the proper installation sequence of parts. First, I installed the curved spring washer (cupped toward the housing), then the small thick washer, then the gear, and then the nylon washer. Is this the correct order?
What am I doing wrong? Am I correct that the pot metal gear should rotate relatively freely when the intermediate plastic gear is not installed? Are the warped covers causing the problem (It seems that this would actually allow the gear more freedom)? Are covers commonly warped? Would someone be willing to sell a pair of covers that are not warped? Help.
Thank you.
Thank you.
