This failed motor came to me to diagnose. It was previously working, then externally restored, a new reproduction cast gear installed, lubed up.... but after reassembly it would no longer run.
Here it is when it came to me today.
First I tried turning the thumbscrew but it was very tight.
Then I connected it to a battery to see it fail electrically. No movement whatsoever.
I removed the gearbox cover and gears to then test the motor separately.
It was still very tight without the gears and cover installed using the thumbscrew, but a tad easier than when it was all together. I then connected a 12V battery source and a ammeter to check the current draw. It was about 9 amps and the motor would hardly turn.
Bare motor test, no gears
I then opened up the motor case by removing the gearbox housing for diagnosis. This is done by removing the 2 long hex head screws. There are 2 special clips holding the brush plate to the case. Pry those up and raise the plate up and over the end of the shaft.
Note one brush lead connects to the motor case. This is the ground path for the motor. It is tack welded to the case so use caution when removing the brush plate. The other brush lead attaches to the thermal breaker. Check the contacts of the breaker and clean slightly if needed. If the motor overloads the breaker will open then close on cool down.
The armature and the end frame bushing. Both ends of the armature shaft and both bushings were quite dry. However this unit was in very nice condition and just needed some lubrication.
I tested the armature using my Growler to check for shorts to ground and open commutator contacts. All tests passed.
Growler video
I then cleaned the commutator using the lathe with 1000 grit paper. Then using the backside of a X-Acto knife blade I cleaned all open spaces between contacts. Then I polished both shaft ends using the lathe again.
Jerry_HL_Motor_0029.jpgJerry_HL_Motor_0030.jpgJerry_HL_Motor_0031.jpgJerry_HL_Motor_0033.jpgJerry_HL_Motor_0037.jpgJerry_HL_Motor_0038.jpg
Lathe work
I then cleaned the bushings using a rotary wire brush. Then I oiled both shaft ends and the 2 bushings, one in the motor endframe, the other in the gearbox housing. I use a light sewing machine grade oil which flows easily. Note there is a very small felt wick in the endframe. Soak the wick with oil.
I then reassembled the motor without the gearbox to test it separately.
The armature is placed into the motor housing and its end shaft through the endframe bushing. With brushes inserted in their holders, the brush plate is reinstalled with the side clips set into the recesses in the motor housing. Then the brush springs are reinstalled. Note their orientation.
Jerry_HL_Motor_0043.jpgJerry_HL_Motor_0044.jpgJerry_HL_Motor_0045.jpgJerry_HL_Motor_0046.jpgJerry_HL_Motor_0047.jpg
I tested the motor(without gearbox)and it ran fine. Cleaning and Lubrication fixed it.
Motor test no gears
I then reassembled the gears and gearbox cover.
Note: The orientation of the large cast metal gear and washers is important. First the small diameter steel washer into the housing, then the large diameter beveled spring washer with cone facing up, then the gear, then the plastic washer over the gear.
EDIT... I am researching this more as there has been years of confusion about this "washer" order/configuration. All GM documentation shows the washers a certain way but I've had many problems with motors over the years when configured that way. More to come.
Use a good grade of grease on the gears, but not too much. Don't use lithium grease.
Then the 4 screws for the gearbox cover are then installed and tightened. Then I tested the motor assembly and it ran properly in both directions. I then adjusted the armature shaft end play by loosening the locknut then turning the stud adjuster screw until the motor just started to drag, then back until I could hear the speed increase, then tightened the locknut while holding the screw.
Note that the end play screw on this motor appears a bit longer than typical. I have seen both lengths. Here are a few photos and measurements. Note on some screws there is a plastic button on the end that contacts the armature shaft. There is a cavity in the end of the screw and the button is pushed into it. Some do not have the button.
The two problems appeared to be insufficient lubrication and dry bushings in the motor portion and incorrect order of one of the washers in the gearbox portion. All fixed. Motor draw around 4.8 amps now.
Final Test
Rich
Growler video
Lathe work
Motor test no gears
Final Test
Rich
