61 Corvette Clock Lens Replacement - NCRS Discussion Boards
  • Mark S.
    • July 31, 1983
    • 662
    I replaced the lens in the gauges for my 1961 Corvette. The last of my chores is to replace the lens for the clock. Does the stem for the hands come out for the lens to be replaced? If so, how? Thanks, in advance!
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11329
    Mark, The stem stays put.
    The knob unscrews, CCW.
    Pull the knob and use needle nose pliers to hold the stem, then remove the knob.
    Now uncrimp the bezel at the crimp locations, then remove it. Note orientation of the black inner ring behind the lens. It's very delicate, so use caution.
    Replace the lens & ring, then the bezel. Recrimp the bezel at the same spots.... and it's done.
    • Mark S.
      • July 31, 1983
      • 662
      Rich: Thank you very much for the tutorial! You are the best! Sincerely, Mark
