61 Corvette Clock Lens Replacement - NCRS Discussion Boards
  • Mark S.
    • July 31, 1983
    • 664
    I replaced the lens in the gauges for my 1961 Corvette. The last of my chores is to replace the lens for the clock. Does the stem for the hands come out for the lens to be replaced? If so, how? Thanks, in advance!
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11363
    Mark, The stem stays put.
    The knob unscrews, CCW.
    Pull the knob and use needle nose pliers to hold the stem, then remove the knob.
    Now uncrimp the bezel at the crimp locations, then remove it. Note orientation of the black inner ring behind the lens. It's very delicate, so use caution.
    Replace the lens & ring, then the bezel. Recrimp the bezel at the same spots.... and it's done.
    Rich
    • Mark S.
      • July 31, 1983
      • 664
      Rich: Thank you very much for the tutorial! You are the best! Sincerely, Mark
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11363
        Mark, I found these photos of a 1958 Chevrolet Passenger Car Clock I cleaned up and fixed a few years ago. It shows the parts when disassembled.
        Rich
        Here's a video of the internals....
        • Mark S.
          • July 31, 1983
          • 664
          Thanks again Rich. This is helpful! Mark
          • Roger W.
            • January 29, 2008
            • 572
            Rich. Do you lubricate any parts in the clock mechanism?
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11363
              Roger,
              I use a electrical contact cleaner on the internals, then blow it out with compressed air.
              I then use a very light sewing machine oil, just a touch on a needle, and apply it only to the gear shafts. Just a tiny amount.
              I've done many clocks this way and seems to work well.
              Rich
