1966 L72 F 41 front suspension, steering questions. - NCRS Discussion Boards
  • David H.
    • June 30, 2001
    • 1545
    Originally posted by Mark Franey (68639)
    Pat. Thats a good idea, I have about 5 gallons of Evapo rust that is currently being used on suspension and steering parts. I will put the springs in it when they get finished.
    Do you think blasting the coil springs would hurt them? I was going to farm this job out as I do not have a blast cabinet. But will not do it if it could damage these springs.
    Thanks. Mark
    Mark
    Media blast is just going to knock rust/dirt/etc off, so blast away! If springs are in that poor a condition (and yours don't look like that) you would not want to use them. I used a fine glass media blast for mine - nice surface for paint.
    Dave
      • 11678
      I'm not sure that blasting will harm them. It just appears that there is some original scaling still present, which I thought might be interesting to keep.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11345
        #18
        That divot you see on one end of the coil is likely from the manufacturing process. One end is fixed to a holder chuck with a sharp edge while the heated bar is rotated on the forming spool.
        Note left end of this coil spring.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11345
          #19
          At about 35 seconds in you'll see the clamp....
