1966 L72 F 41 front suspension, steering questions. - NCRS Discussion Boards
  • Mark F.
    • December 1, 2021
    • 89
    Redoing front suspension/steering on my 1966 L72. First time doing this project so have a couple questions. (Also found out car was originally a power steering car so will be asking questions about that in a separate thread.)
    Suspension question.
    Front F41, 7 coils spring is 12 3/8 inches uncompressed. (Both left and right about same.) Ride height on car is good. I am not looking for trouble just don't want to go through this pain again. Should I send them out to be checked?
    Coil spring orientation. Does it matter how they go into the car, which end of the spring goes up as they look symmetrical? (picture below.) I put a wire on the installed upside just in case.
    Steering question.
    Does anyone rebuild original idler arms?
    Thanks guys. Mark
  • Gary B.
    • February 1, 1997
    • 7060
    Originally posted by Mark Franey (68639)
    …Does anyone rebuild original idler arms?…
    Mark,
    Not that I’ve ever heard of.
    NOS examples, if you can find one, typically have a zerk fitting, which is not correct for judging. If your original idler arm isn’t obviously sloppy, siezed, grinding, etc., I’d consider cleaning it up and reusing it.
    Gary
    • David H.
      • June 30, 2001
      • 1552
      ... Coil spring orientation. Does it matter how they go into the car, which end of the spring goes up as they look symmetrical? (picture below.) I put a wire on the installed upside just in case. ... Mark
      Mark
      Orientation of spring does matter.
      Page UPC 3, A4 of your 1966 Assembly Manual (AIM) has a note with instructions. "End of coil 0.38" plus or minus 0.12" from stop"
      That is upper stop. (hole in lower A-Arm is a drain)
      Your spring does not appear to be "a progressive wind". If it was a progressive spring (coils compressed at one end and more open at other end), then the "tight" coil end would be up into shock tower.
      ​​​​​Dave
      • Mark F.
        • December 1, 2021
        • 89
        Originally posted by Gary Beaupre (28818)
        Mark,
        Gary
        Thanks Gary. My idler arm may OK. I used a clamp that pushes the stud out of the drag/relay link, and I have to check the idler arm stud threads I may have buggered them up but I think its salvageable. Other than that, it still looks and rotates good. Just thought I would have someone go through it as I wait for gear box and control arms to get back. Thanks for help. Mark
        • Mark F.
          • December 1, 2021
          • 89
          Originally posted by David Houlihan (36425)
          Mark
          ​​​​Dave
          Thanks Dave. I have not looked for stop in the shock tower but will do so when I get the A-arms out today or tomorrow. I think I have read there is an inspection/viewing hole at the top of the shock tower that coincides with the stop. How you are supposed to see the end of the spring 3/8 inch away from that hole will be interesting. It might become self evident when I get around to reinstalling the spring.
          OK, no top or bottom of the spring, thanks. Mark
          • Gary B.
            • February 1, 1997
            • 7060
            Mark,
            The AIM has a poor illustration, but if you insert a (3/16”?) drill bit into the 3/16” ((?) hole in the upper shock tower, it will serve as a stop against the end of the coil spring and it will position the end of the coil in the right place relative to the “stop” referred to in the AIM, which is the end of the channel in the tower.
            Gary
            • David H.
              • June 30, 2001
              • 1552
              Mark
              Photo below is looking down on spring inserted in shock tower. You can see spring through alignment hole.
              End of spring is visible in hole.
              Dave
              • Mark F.
                • December 1, 2021
                • 89
                Thanks Dave. I appreciate the pictures. After looking at your photos went out and looked at the car. (Have just got the upper A arms off last night.) Looks like one side of the circumference of the hole is about the .38" from the coil spring stop. So, if your spring covers most of the hole with just a little bit of space left you should be within the .38+/-.12 from the stop.
                Would I be accurate to say that in your zoomed out picture is a spring compressor with a bolt on the end to hold the spring in place to get the exact alignment before you bring up the lower control arm and fasten the ball joint bolts?
                Those are great photos and I appreciate you taking the time to send them.
                Cheers. Mark
                • David H.
                  • June 30, 2001
                  • 1552
                  ... Would I be accurate to say that in your zoomed out picture is a spring compressor with a bolt on the end to hold the spring in place to get the exact alignment before you bring up the lower control arm and fasten the ball joint bolts? ...
                  Mark
                  These images were part of a photo from a post on CF - I added verbiage and arrow. On my Small Block I used a compressor - I had too, given spring's length. On your Big Block, again given spring length, you might not need a compressor.
                  I'd use a compressor just to hold spring in place and make assembly easier.
                  Dave
                  p.s. as you marked upper on your springs, just curious as if you can see a divot or some other stamping mark.
                  • Mark F.
                    • December 1, 2021
                    • 89
                    Dave: just went out and looked at my springs that are very crusty. I will attach a few pictures that if you use your imagination, you may see a small divot. This was on the bottom of my right spring. The ball joints on the car were replaced so the spring has been out of the car before. The left spring had nothing. After I get them blasted something may become more apparent and if so I will post.
                    • Mark F.
                      • December 1, 2021
                      • 89
                      Dave; Just took a power washer to both springs and you can clearly see a divot on the springs. I will attach a picture of my left spring, but both have a divot clearly visible. In my car these were installed on the lower side. Ball joints were replaced before, so if the divot is supposed to be on the upper side they put them in upside down. Since the springs are not progressive, I guess it did not matter, but will be installing them with the divot side up. Cheers. Mark
                      • Mark F.
                        • December 1, 2021
                        • 89
                        Here is the left spring
                        You do not have permission to view this gallery.
                        This gallery has 3 photos.
                        • David H.
                          • June 30, 2001
                          • 1552
                          Mark
                          My 1980 had same divot marks! I also reinstalled with divot up - suspension on mine had never been apart.
                          Not being progressive, I think it doesn't matter.
                          Dave
                            • 11689
                            You might consider Evapo-Rust or similar, rather than blasting them. I used a glass vase to hold the Evapo-Rust, and inserted the spring. Those springs look relatively good afte the power washing.
                            • Mark F.
                              • December 1, 2021
                              • 89
                              Pat. Thats a good idea, I have about 5 gallons of Evapo rust that is currently being used on suspension and steering parts. I will put the springs in it when they get finished.
                              Do you think blasting the coil springs would hurt them? I was going to farm this job out as I do not have a blast cabinet. But will not do it if it could damage these springs.
                              Thanks. Mark
