1966 Grill Bracket Screws - NCRS Discussion Boards
  • Walter R.
    • January 6, 2009
    • 271
    I am in the process of installing grill. Zip list phillips head screws as avalible and I purchased. These screws attach the grill bracket to the bracket that is rivited to the body. I am in need of the 4 screws and attaching nut that fastens grill to bracket. These screws would be 3/16". I called Zip and they have no listing. Would anyone know if they are available?
  • Jack M.
    • March 1, 1991
    • 1185
    Walter- Many of the 1966 AIM's are missing page (UPC 11-13) (SHEET B-1)
    See if this page helps with your part numbers to order:
    • Robert P.
      • October 19, 2019
      • 318
      Zip # GR-335 should be the ones
      Bob
      • Walter R.
        • January 6, 2009
        • 271
        The screws or bolts I am in need of attach the grill to the bracket the attaches to the brackets on the body. That page does not show those screws/bolts. GR-335 are not the screws I need as the screws would have to be 3/16 as the hole in the bracket as well as the grill is 3/16". GR-335 is 1/4". I would believe it would possibly be the same type of phillips head screw but 3/16"
        • Gary B.
          • February 1, 1997
          • 7054
          Walter,
          Are you talking about attaching the bracket that is riveted to the grill?
          Gary
          • Tom D.
            • September 30, 1981
            • 2139
            https://MichiganNCRS.org
            Michigan Chapter
            Tom Dingman
            • Walter R.
              • January 6, 2009
              • 271
              That is it. The brackets are rivited to the grill. I had evidently read it incorrectly. I thought the brackets that are attached to the body were the only ones rivited. Thank you for the clarification.
              • Robert P.
                • October 19, 2019
                • 318
                The brackets to the fiberglass body are 3/16 rivets and the correct screws for the grille to brackets are the 1/4 20 screws with captured washers which I posted
                Bob
                • Walter R.
                  • January 6, 2009
                  • 271
                  Is the head on the outside of the grill and it is peened on the inside?
                  • Joseph S.
                    National Judging Chairman
                    • March 1, 1985
                    • 893
                    Walter, The small brackets are attached to the grill with Aluminum button head rivets, not screws.
                    • Mike M.
                      • December 20, 2013
                      • 33
                      Walter - the rivets are all oriented from the top down and peened on the bottom.
