C2 Frame shim tape installation question - NCRS Discussion Boards
  • Robert P.
    • October 19, 2019
    • 319
    Looking to find some info on shim tape installation on a 66 , I am sure there is a right way and a over restored way to do this
    thanks in advance
    Bob Peckham
  • Harry S.
    • July 31, 2002
    • 5338
    https://www.forums.ncrs.org/forum/te...ape#post371209
    • Alan D.
      • January 1, 2005
      • 2052
      On my 64 the tape was over the shims (not sure if all of them) and around the cushion.
      That seems to be a little different than what is being talked about.
      "not sure if all of them" was able to verify it's over all the shims, able to see some on center shims.
      However that tape still exists on my Mar64 and the body has never been off.
      Just an example of "one"
      Last edited by Alan D.; April 29, 2025, 11:45 AM. Reason: Verify tap at center location.
      • Robert P.
        • October 19, 2019
        • 319
        I had a little tape left from a few of the mounts seemed like the tape just draped over the shims but I thought the mount by the kickup had it wrapped around like in the picture in the link
        thank you Bob
        • Jack M.
          • March 1, 1991
          • 1187
          Bob- This Corvette assembly line image was taken on September 28, 1965.
          John Hinckley had shared it with me... I've tried to enhance & enlarge the area for you.
          • Robert P.
            • October 19, 2019
            • 319
            Jack , thanks for trying to blow up the picture , looks like mount 2+5 the tape is place over the shims but on number 4 it looks like it has some tape wrapped around along with a piece going over the top but doesn't look like its 2" wide but can't be certain
            Bob
            • Jack M.
              • March 1, 1991
              • 1187
              Bob- The previous images were from a 1966 convertible, this coupe was next in line:
              Although from 1963, these images may give you a better look at the width of the tape:
              • Robert P.
                • October 19, 2019
                • 319
                Jack , those are very helpful thank you very much
                Bob
