2006 PV Prep. - NCRS Discussion Boards
2006 PV Prep.
  • Harry S.
    • July 31, 2002
    • 5342
    2006 PV Prep.
    Well, getting ready for a PV at Marlborough this month.
    So far, I've spent many hours with the following:
    • Reset the TPMS with a reset tool
    • Zip-tied the yellow connector under the driver's seat to avoid code B0041
    • Zip-tied the yellow connect tighter to the bottom of the driver's seat to avoid code B0041
    • New batteries in the FOB's
    • Fixed all the deducts from the Regional Flight Judging that I could
    • Clean the drilled rotors
    • Put on the new (NOS) wiper blades
    Now I can start the PV at the house and fix whatever has a problem. Fingers crossed.
    • 11692
    Re: 2006 PV Prep.
    Good luck, Harry.
    Keep us posted on your prep, and any pitfalls you run into.
    PH
    • Ed H.
      • November 1, 1999
      • 626
      Re: 2006 PV Prep.
      Harry, one more small detail, test fit and operation of the two trunk keys attacked to each FOB. I found one key had a difficult time seating completely due to ****z in the key lock mechanism, also I had to use a wirebrush to clean metal fibers on one key, MAY THE PV GODS BE WITH YOU.
      • Harry S.
        • July 31, 2002
        • 5342
        Re: 2006 PV Prep.
        Thanks, Patrick & Ed.
        • Brian M.
          • February 1, 1997
          • 1840
          Re: 2006 PV Prep.
          Best of Luck Harry.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11362
            Re: 2006 PV Prep.
            Harry,
            How's the E-Brake? I recall you have to drive at xx MPH, then slam E-Brake to stop the car.
            After your test run, check TPMS 4 corners again, to make sure they're reading properly.
            It's possible the pendulum effect of the abrupt stop could affect pressure readings.
            Rich
            P.S. Ed H told me this, as it happened to his car.
            • Chuck G.
              • May 31, 1982
              • 2039
              Re: 2006 PV Prep.
              Good luck, Harry.
              • Ed D.
                • December 1, 1990
                • 329
                Re: 2006 PV Prep.
                Best of Luck Harry. Let us know how it goes. Potential 2011 in the future for me.
                Ed
                Ed DiNapoli
                CNJ Chapter Past Chairman/Co Founder
                1972 Targa Blue Coupe, Original Owner,
                Duntov Award, Sam Foltz Award,
                Founders Award, NCRS Gallery VIII
                2011 Corvette Convertible
                NCRS Presidents Award 2014
                  • 6955
                  • Ed H.
                    • November 1, 1999
                    • 626
                    Re: 2006 PV Prep.
                    Rich, the application of the Ebrake is accomplished at approximately 3-5 mph first forward then reverse the 35-40 mph is the test of the ABS SYSTEM. That test is what caused my TPWS to record (0) on my DIS, Pete invoked the 15 min rule, that turned out OK
                    • Michael J.
                      • January 27, 2009
                      • 7166
                      Re: 2006 PV Prep.
                      Good luck Harry, but you are gonna wish you were back in your '63......
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11362
                        Re: 2006 PV Prep.
                        Ed, Thanks for clarifying that.
                        Rich
                        • Harry S.
                          • July 31, 2002
                          • 5342
                          Re: 2006 PV Prep.
                          To everyone that helped with the preparation for the PV, Thank you.
                          I passed the PV on Friday afternoon. The test was delayed due to rain and wet roads. It took about 2 hours and 20 minutes to complete. Pete Bergman is very good, thorough, and nothing went untested.
                          Now I can relax till the National.
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11362
                            Re: 2006 PV Prep.
                            Harry, Awesome! Congratulations!
                            Well deserved as you worked so hard on the prep.
                            Rich
                            P.S. So I take it...... The Auto-Dimming mirrors worked well. Did Pete do the flashlight thing like we did?
                            • Harry S.
                              • July 31, 2002
                              • 5342
                              Re: 2006 PV Prep.
                              Rich
                              Yes, on the auto dimming. I could not get it to work till I took it out of reverse. Fifteen seconds of sweat!
