Need help on 66 C2 D/S Door Gap - NCRS Discussion Boards
  • Larry E.
    • 1690
    Re: Need help on 66 C2 D/S Door Gap
    Originally posted by Leif Anderson (29632)
    Larry,
    Did you not like the original ones I posted in post #8? Reproductions aren't nearly as sturdy.
    Leif: Not that I do not like but do not have the time for a deal like that since "Judgement Day" is coming up fast.
    Corvette Central has all my info and can have them here in 2 Days. Also I need to order from them to
    Keep my 15% discount. Thanks for the info. Larry
    Larry
    LT1 in a 1LE -- One of 134
    • Larry E.
      • 1690
      Originally posted by Chris Tarjani (10436)
      Strike Plate Grippers
      [ATTACH=CONFIG]121846[/ATTACH]
      Chris: Got my Grippers in from Corvette Central and to my surprise the smaller ones have small "Tabs" coming out from the
      legs. Not sure how they are placed behind the striker plates. Facing the front or rear of car? I may just grind them off since
      it looks like they are not needed. Comments?? Larry
      Larry
      • Chris T.
        • August 31, 1986
        • 30
        #18
        Larry, I believe there is a spacer/shim between the striker and the gripper that has slots for the tabs on the gripper to keep it located.Striker Shim and Grippers.jpg
        • Larry E.
          • 1690
          #19
          Larry, I believe there is a spacer/shim between the striker and the gripper that has slots for the tabs on the gripper to keep it located.[ATTACH=CONFIG]122048[/ATTACH]
          Chris: Thanks for the input; never would have guessed this. Larry
          Larry
