2024 National Convention Rooms - NCRS Discussion Boards
  • Brian D.
    • April 30, 1999
    • 425
    Well, it's 7:53pm on Feb 2nd.
    Apparently all the Embassy Suites rooms are booked?
    The hotel link through our registration page says, "Sorry, we don't have any rooms available for those dates."
    B.D.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17940
    Re: 2024 National Convention Rooms
    Brian,
    This is what worked for me:
    1) go to https://www.hilton.com/en/hotels/phf...ention-center/
    2) click the Special Rates button
    3) put in the NCRS Group Rate code 90X & click Done
    4) put in the Dates
    5) click on Check Rooms & Rates
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Peter H.
      • April 1, 1980
      • 230
        • 11692
        It’s a bit glitchy.
        I did it by choosing dates, then clicking on the Special Rates button and entering the 90X code in the Group rate
        Once I did the rooms opened up.
        • Gary J.
          • April 1, 1980
          • 1246
          I called yesterday morning about 8 AM and the lady told me they only had 4 rooms left. With that being said all the blocks rooms are gone.
          • Vinnie P.
            Editor NCRS Restorer Magazine
            • May 31, 1990
            • 1576
            There are overflow hotels with NCRS rates also, they are all listed here
            • Peter H.
              • April 1, 1980
              • 230
              • Gary C.
                Administrator
                • October 1, 1982
                • 17940
                Peter,
                Suggest you contact your ISP provider about your problem seeing the websites.
                Gary
                NCRS Texas Chapter
                • David H.
                  • June 30, 2001
                  • 1559
                  Originally posted by Peter Hannigan (3522)
                  Can Someone Fix The Issue With The Embassy Suites Reservations. This Is Very Frustrating A Fellow Member Has Tried And Encountered The Same Issues As Me I Can’t Access The Other Hotel Sites
                  Peter
                  Procedure detailed in Gary Chesnut's post above worked for me with no issues.
                  Dave
                  • Brian D.
                    • April 30, 1999
                    • 425
                    A big Thank You shoutout to Gary C and Patrick H!!
                    I was able to get a room through that method.
                    Blood pressure now lower; stress level decreased.
                    Usually I wouldn't have had Feb 1st slip through the cracks...
                    B.D.
                    • Peter H.
                      • April 1, 1980
                      • 230
                      Just To Add To The Confusion The Marriott Hampton Phone Number Should Read 757 838 3300. The Listed # Is A Private Home
                      • Wayne M.
                        • September 24, 2021
                        • 39
                        Me too! Just registered at Embassy Suites. The selection of days for my stay was a little clunky but got I it to work eventually.
                        • Dean N.
                          Infrequent User
                          • 27
                          i had the same problem. i entered the dates of 8-3 to 8-9 and it said full.
                          i called and they told me the NCRS only has room rate from 8-4 to 8-9, so i had to change the date to read 8-4 to 8-9 and now it worked.
                          i than call the hotel and told them i also need room for 8-3 and they gave it to me at the NCRS rate.
                          Dean Nelson
                          Dean Nelson
                          1967 327/300 3-speed- Bowtie - P.V. - Duntov
                          1971 454/425 LS-6
                          1990 LT5 ZR-1 bought new
                          • Mark D.
                            1984-96 Team Leader
                            • June 30, 1988
                            • 2168
                            Greetings from Tel Aviv...I just used Patrick's suggestion and got rooms, no problem.
                            Shalom
                            Kramden
                            • Tim S.
                              • May 31, 1990
                              • 715
                              Thanks Gary and Patrick......worked like a charm. Now if PV's were only that easy
