Re: Dislocated my upper control arm shaft- how to fix?
Yes as Leif noted, the inner sleeve of the bushing pulled out of the rubber housing. I always thought that sleeve was vulcanized to the rubber. It appears that this one was not. Or in this case, it was but tore away from the rubber.
The sleeve seized itself to the shaft, which by design is not uncommon as rust will bond them together. The serrated edges of the sleeve are designed to bite into the shaft end flat circular surface as well as the large washer on the outside. Thus the rotation is designed to rotate by the twisting motion of the rubber, not the mating metal pieces turning.
Do we know enough about replacement bushings and their manufacturing process? I'm beginning to wonder if shortcuts have been made on non-GM replacements, whereas the vulcanizing process has been eliminated.
