Dislocated my upper control arm shaft- how to fix? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1416
    #31
    Re: Dislocated my upper control arm shaft- how to fix?
    Got the upper a-arm out. It was fairly easy. Thanks to Duke and others who posted their technique. I took pics of the removed a-arm, bushings, and shaft. See attached.
    Mike
    • Michael L.
      • December 15, 2006
      • 1416
      #32
      Leif, yeah I was figuring that the upper fronts would be hard to get to. I will see if I can remove the upper radiator support bolts and loosen the lowers and if I can roll the radiator a couple of inches forward. If not I'll loctite them and just tighten the snot out of them as you suggest. As I mentioned previously, I'm going to remove the lower bolts and loctite and re-torque them.
      Rich, although I didn't do these a-arms I've done others and I have a press and will be doing it myself. I see the spacer you used for the lower arms is made out of PCV and the upper is made out of metal. I will make both of mine out of PCV and it's what I've used before.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        #33
        Mike, Both were white painted old metal pipe I had lying around. PVC would work too.
