C2 Cannot Remove Steering Wheel/Turn Signal Housing - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4607
    Re: C2 Cannot Remove Steering Wheel/Turn Signal Housing
    Originally posted by Mark Hedberg (30810)
    Final question - my copy of the AIM is very hard to read. Can anyone verify the torque value for the bolt on the firewall side of the rag joint (where the shaft is inserted)? Best I can tell it's 35 ft-lbs, but hoping to verify. Thanks.
    Mark
    The shop manual might also have the torque value.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Frank D.
      • December 27, 2007
      • 2703
      There is this document that I've gone by for a lot of the torque settings...
      It agrees with Norm's specs above @ 30 ft-lbs...
      • Mark H.
        • July 31, 1998
        • 384
        #18
        Thanks to all. Frank, that torque chart is great.
        • Joseph S.
          National Judging Chairman
          • March 1, 1985
          • 930
          #19
          Happy to help. I use this method often. In my opinion it's much easier than removing the hub if you just need to do minor work in the housing.
            • 15706
            #20
            I'm a bit suspicious of a couple of those values. For years I've had a card with "standard torque values" based on shank diameter and grade. In the event I can't find what I consider to be a reliable torque spec in the service manuals or AIM I use the card value.
            I'm sure there are charts on the Web with the same info.
