C2 Cannot Remove Steering Wheel/Turn Signal Housing - NCRS Discussion Boards
  • Mark H.
    • July 31, 1998
    • 384
    The turn signal stalk on my '64 is coming loose, so I thought I would spend an hour or so and tighten it up. Ha! Easy enough to remove the horn button, wheel and nut and washer. Installed my steering wheel puller and it seems to be frozen solid. it won't budge. I've soaked in penetrant several times, left the puller under tension over night and tapped it with a hammer to no avail. Not budging, 2 days later. Am I missing a locking piece somewhere? I don't see one mentioned in the shop manual or shown in the A.I.M. Thanks.
    • 6960
    • Mark H.
      • July 31, 1998
      • 384
      Re: C2 Cannot Remove Steering Wheel/Turn Signal Housing
      Thanks. I started with a harmonic balancer puller but mine is just a little too large - the two bolts that go into the hub won't line up. I'm using this steering wheel puller
        • 6960
        • Mark H.
          • July 31, 1998
          • 384
          I think that's a function of the housing threads - when the bolts are screwed in all the way, they are not perfectly parallel.
            • 6960
            Mark, I see that the bolts are tilted slightly, try tightening the bolts with the point tip centered as close as possible.thereโ€™s no other tricks, I have been in the auto business for 40 years and cannot say I have seen one that was so tight it would not remove the hub. I know I have had some that require more pressure, can you try some slightly shorter bolts the one your using maybe a bit long.
            • Bill M.
              • 1329
              Try hawing a heat gun all around the hub
              • Bill M.
                • 1329
                Hate this auto spelling. Try using a heat gun to heat the hub
                • Frank D.
                  • December 27, 2007
                  • 2703
                  If you just need to tighten up the turn signal "stalk" there is a flat spot on it you can put blue tape on and use pliers or the like to tighten it up sufficiently. Unless something is going on with the interanls.
                  • Joseph S.
                    National Judging Chairman
                    • March 1, 1985
                    • 933
                    Mark, If you can't get the hub off. Remove the bolt from your steering coupler, loosen the small clamp on your lower shaft and pull the hub and shaft together. Tighten your directional lever then slide the shaft back into place and re-tighten everything.
                    Joe
                    • Mark H.
                      • July 31, 1998
                      • 384
                      Frank and Joe thanks for these suggestions. If it hasnโ€™t come loose by the weekend (left it under tension) I will give those a try.
                      Mark
                      • Gerard F.
                        • June 30, 2004
                        • 3806
                        Mark,
                        Take a look at this thread of some years ago of my change the signal switch on my 67 and without using a steering wheel puller:
                        How this for a Touring Car (ncrs.org)
                        See post 10 of the thread
                        Leave the steering wheel on. Loosen the nut that holds the coupler on the shaft, bring it to the top of the shaft slightly above the threads. Then have someone wack the nut with a hammer while you rock and pull on the steering wheel.
                        Worked for me at a Lake Tahoe NCRS event on my 67 when I didn't have a puller
                        Jerry Fuccillo
                        • Bill M.
                          • 1329
                          Heat up the hub with a heat gun. Heat loosens everything
                          • Mark H.
                            • July 31, 1998
                            • 384
                            Joe's suggestion wins the day. Loosening the bolts i was able to pull the shaft out just enough to tighten the turn signal lever without removing the shaft from the rag joint. Final question - my copy of the AIM is very hard to read. Can anyone verify the torque value for the bolt on the firewall side of the rag joint (where the shaft is inserted)? Best I can tell it's 35 ft-lbs, but hoping to verify. Thanks.
                            PS - I tried heat first, but it started smoking out the back of the hub assembly, so shifted to plan B.
                            Mark
                            • Norm B.
                              • 360
                              If it's Bolt 5 (Part # 5686553) on Page C170 you are asking about my AIM shows 25-35 lbs. ft. of torque.
                              Golf is for those who can't playโ€‹ hockey.
