Re: '67 Front Spindle Steering Arm Mount Nuts
Leif
Below are torque specs from Van Steel's web site.
Dave
Leif
Dave
| C2/3 Corvette Typical Torque Specs |
| Part # Description Torque Spec |
| SB-06 Sway Bar Frame Mount Bolts 20 ft ft/lbs |
| FS-27K Lower A-Arm 2 Hole Plate 70 ft/lbs |
| FS-37 Front Upper Backing Plate Bolt 130 ft/lbs |
| FS-38K Front Lower BA Bolts 55-60 ft/lbs |
| FS-39K Front Lower BA Bolts 85-90 ft/lbs |
| ST-03 Upper Idler Arm Bolt 35-40 ft/lbs |
| ST-04 Lower Idler Bolt 35-40 ft/lbs |
| GB-32 Steering Box Bolts 35-40 ft/lbs |
| FS-06 Upper A-Arm Bushing Bolts 35 ft/lbs |
| FS-09 Alignment Stud Nuts 50 ft/lbs |
| FS-23K Lower A-Arm Bushing Bolts 70 ft/lbs |
| FS-28K Lower A-Arm Rear Bolt 100 ft/lbs |
| TA-22 T-Arm Bolt Kit NO Torque Spec |
| TA-23S T-Arm Bolt & Shim Kit NO Torque Spec |
| SR-17K Eccentric Bolts 100 ft/lbs |
| FC-09PK Pinion Bushing 70 ft/lbs |
| FC-09R Pinion Bushing 70 ft/lbs |
| SR-13K Strut Rod Bracket Bolts 35-40 ft/lbs |
| SR-20 Upper Shock Mount Bolts 55-60 ft/lbs |
| SG-47 7/16-20 Nuts 35 ft/lbs |
| SG-54 7/16-20 Nuts 35 ft/lbs |
| SG-30K Diff X-Member Bolts 50-55 ft/lbs |
| RB-31K Caliper Bolts 70 ft/lbs |
| FC-11k Pinion Bracket Bolts 50 ft/lbs |
| VS-97456 Alignment Studs 35 ft/lbs |
