'67 Front Spindle Steering Arm Mount Nuts - NCRS Discussion Boards
  • David H.
    • June 30, 2001
    • 1544
    Re: '67 Front Spindle Steering Arm Mount Nuts
    Leif
    Below are torque specs from Van Steel's web site.
    Dave
    C2/3 Corvette Typical Torque Specs
    Part # Description Torque Spec
    SB-06 Sway Bar Frame Mount Bolts 20 ft ft/lbs
    FS-27K Lower A-Arm 2 Hole Plate 70 ft/lbs
    FS-37 Front Upper Backing Plate Bolt 130 ft/lbs
    FS-38K Front Lower BA Bolts 55-60 ft/lbs
    FS-39K Front Lower BA Bolts 85-90 ft/lbs
    ST-03 Upper Idler Arm Bolt 35-40 ft/lbs
    ST-04 Lower Idler Bolt 35-40 ft/lbs
    GB-32 Steering Box Bolts 35-40 ft/lbs
    FS-06 Upper A-Arm Bushing Bolts 35 ft/lbs
    FS-09 Alignment Stud Nuts 50 ft/lbs
    FS-23K Lower A-Arm Bushing Bolts 70 ft/lbs
    FS-28K Lower A-Arm Rear Bolt 100 ft/lbs
    TA-22 T-Arm Bolt Kit NO Torque Spec
    TA-23S T-Arm Bolt & Shim Kit NO Torque Spec
    SR-17K Eccentric Bolts 100 ft/lbs
    FC-09PK Pinion Bushing 70 ft/lbs
    FC-09R Pinion Bushing 70 ft/lbs
    SR-13K Strut Rod Bracket Bolts 35-40 ft/lbs
    SR-20 Upper Shock Mount Bolts 55-60 ft/lbs
    SG-47 7/16-20 Nuts 35 ft/lbs
    SG-54 7/16-20 Nuts 35 ft/lbs
    SG-30K Diff X-Member Bolts 50-55 ft/lbs
    RB-31K Caliper Bolts 70 ft/lbs
    FC-11k Pinion Bracket Bolts 50 ft/lbs
    VS-97456 Alignment Studs 35 ft/lbs
    • Leif A.
      • August 31, 1997
      • 3642
      Dave,
      Thanks for the additional information...always helpful.
      Leif
      • Leif A.
        • August 31, 1997
        • 3642
        #18
        Just a quick follow-up. I received my spindle bolts and nuts a couple of days ago and decided to install today. Not a bad job at all. I took my time and did the passenger side first...one hour and forty five minutes. Driver side forty minutes. Glad to have it done...all torqued to 70 lb ft. Again, thanks for everyone's input.
        Leif
