'67 Front Spindle Steering Arm Mount Nuts - NCRS Discussion Boards
  • Leif A.
    • August 31, 1997
    • 3651
    I noticed when servicing my '67 a few weeks back that the front spindle steering arm mount nuts were loose...what a mini PITA this is going to be having to remove so much "stuff" just to get to the head of the bolt. My question is, are the nuts a "one time use only" type. I know they're self locking so I'm guessing they're one and done. Just want to have new ones on hand should I need them.
    Or, does anyone have any ideas as to how to tighten the nuts without being able to get to the head of the bolt to hold it.
    Thanks guys.
    Leif
    • 43273
    Re: '67 Front Spindle Steering Arm Mount Nuts
    Thanks guys.
    Leif------
    The nuts can be re-used. In fact, the exact same nuts were used on the rocker arms of many Chevrolet engines and those nuts are commonly re-used. However, if your nuts have loosened, that's a sign that they have lost some locking capability and I would replace them. These nuts are a "stover" type locknut and may not be easy to find. The GM part number was 9422300 but it's long since GM-discontinued
    • Gary B.
      • February 1, 1997
      • 7065
      AMK Products sells a repro of GM 9422300 nut. But they have a $30 minimum order.
      Gary
      • Ed S.
        • August 6, 2014
        • 1388
        Lief,
        If you question the integrity of the bolts (or nuts) and are going to go through the effort to get access to the bolts - rather than re-use anything suggest you consider replacing the nuts and bolts - a set of 4 nuts & 4 bolts is less than $10. If those bolts were over torqued the bolt might have been stretched enough to contribute to the nuts working their way loose. Good early winter project...... don't you think!
        Ed
        • Leif A.
          • August 31, 1997
          • 3651
          Thanks everyone. I have the answers I need. I had already put the bolts and nuts in my cart from Zip...the cost of which is most likely less than the shipping will be I was hoping against hope that someone had a novel way of tightening a nut without being able to stabilize the bolt...I'm guessing no such luck.
          Leif
          • David H.
            • June 30, 2001
            • 1559
            ... I was hoping against hope that someone had a novel way of tightening a nut without being able to stabilize the bolt...
            Leif
            SOMETHING caused those fasteners to become loose.
            I would carefully disassemble that entire structure to determine root cause and what additional damage you may have.
            More than bolts may need to be repaired/replaced.
            Dave
            • Leif A.
              • August 31, 1997
              • 3651
              Originally posted by David Houlihan (36425)
              Leif
              Dave
              Dave,
              Thanks for the heads up. I will be looking over everything very carefully as I disassemble. BTW, what is the proper torque spec for this nut??
              Leif
              • David H.
                • June 30, 2001
                • 1559
                Dave,
                Leif
                I do not have torque specifications for a 1967 suspension - should be in your Service/Shop Manual.
                Dave
                  • 43273
                  Leif
                  Dave
                  Dave-----
                  It's not. I've never found the torque value for those bolts in ANY C2 or C3 service manual. Since these were part of an assembly installed at St. Louis, there's no torque value in the AIM's either.
                  I recommend 65-70 ft/lbs for 1963-67 and 95-100 ft/ lbs for 1968-82.
                  • Leif A.
                    • August 31, 1997
                    • 3651
                    Dave-----
                    Thanks Joe. I did not find it in my ST-12 or other service manual either.
                    Leif
                    • David H.
                      • June 30, 2001
                      • 1559
                      Lief
                      Attached are torque values from 1980 Shop Manual.
                      Dave
                        • 43273
                        Lief
                        Dave
                        [ATTACH=CONFIG]109373[/ATTACH]
                        Dave------
                        Yes, I'm familiar with this. However, the torque for the bolts/nuts in question are not shown on this table.
                        • Gary B.
                          • February 1, 1997
                          • 7065
                            • 43273
                            Originally posted by Gary Beaupre (28818)
                            Yeah, you really have to know if a given nut or bolt for 1980 is a different size or grade from the target year. For example, I think the steering knuckle bolts changed from 7/16” for 1963-1967 to 1/2” in 1968.
                            Gary
                            Gary------
                            They did change for 1968-82. That's why I have different torque recommendations for 1963-67 versus 1968-82. The bolts and nuts for all are SAE grade 8.
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11363
                              fixed image
