69 K66 Ignition - NCRS Discussion Boards
69 K66 Ignition
  • Lawrence S.
    • April 1, 1993
    • 804
    #46
    Re: 69 K66 Ignition
    What if the #1 position of the cap is right in line with the rotor tip? What should I do then?
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11364
      #47
      Re: 69 K66 Ignition
      Lawrence that's indicating your balancer timing mark is at pointer 0* or very close to it. Is your balancer at 8*A(below 0)? If not what is it at?
      Rich
      PS I'm in and out of my metal building no signal shop so ill check back when possible.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        #48
        Re: 69 K66 Ignition
        Lawrence I'm going to Email or PM my phone# to you. I'm going back in the shop with no access here for quite a while.
        We can update diagnosis here for reference later.
        Rich
        • Lawrence S.
          • April 1, 1993
          • 804
          #49
          Re: 69 K66 Ignition
          Ok send it on please.
          • Lawrence S.
            • April 1, 1993
            • 804
            #50
            Re: 69 K66 Ignition
            Many thanks to Rich for all the help with my car. I have the static timing set at 8*, and the timing map seems to be in line with Rich and Dukes recommendations.i have converted to full manifold vacuum with a B26 can.
            i have a few other things to sort out but chipping away at it.
            • James G.
              • August 22, 2018
              • 810
              #51
              Re: 69 K66 Ignition
              Lawrence,
              Did you buy a repro 263 coil?
              I have been thinking about picking up a repro as spare 272 for the LT1's while they are available - was wondering your thoughts about the repro -
              A friend offered a GM NOS 207 non embossed -delco 514 -for the same price, however for judging I would still want a technically Correct spare.
              James A Groome
              1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
              1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
              My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
              Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
              • Lawrence S.
                • April 1, 1993
                • 804
                #52
                Re: 69 K66 Ignition
                Hey James. Yes bought a repro 263, but have since bought an original 207 service replacement for the 263. The jury is still out on the 263. I am having popping problems at high revs but at this point not sure it is a fuel delivery problem or the coil, or both! I know I have a fuel delivery problem..had that prior to installing the TI distributor. When I have time will trouble shoot the fuel issue, correct that then move to the coil. I don't have the coil yet but will soon.
                My 69 Z28 was popping at high revs changed the coil all popping went away.
                Will update when I am complete. Other than that car runs well.
                • Lawrence S.
                  • April 1, 1993
                  • 804
                  #53
                  Re: 69 K66 Ignition
                  I installed the 207 coil and no popping, but I still need to rev the car a little higher to confirm no popping at revs above 5k. I won't take it to 6500 just due to age and don't want to risk scattering the engine. But I do think the repro coil was the culprit as many have reported in the past.
                  The car has never run this good while I have owned it. So happy to get one more thing sorted out.
                  I still have a fuel flow issue. I will see if the fuel inlet filter is clogged or look for something else. Once the car starts and I knock the choke off (car is not all the warm at this point) if I blip the throttle there is a stumble.
                  Any ideas?
                  Lawrence
