63 Storage heartburn - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2157
    Re: 63 Storage heartburn
    I really could use some of those shims, if anyone has them. Got some from Mike M. a while back, but searched high and low and found no trace of them in my vast collection of 63 parts...got any more Mikey?
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • Harry S.
      • July 31, 2002
      • 5295
      Well, I double checked all the fuel and brake connections and took a test ride. I need to:
      1. Adjust the choke at cold start
      2. Adjust the carb.
      3. Adjust the brakes as it pulls to the left when stopping
      4. Adjust clutch
      5. Adjust Booster/MC pin (it's a 63 with the one year only adjustment)
      Suppose to snow tomorrow, so I'll do some of it.
      Great hobby, isn't it.
      • Frank D.
        • December 27, 2007
        • 2703
        #18
        OK Harry, once again I have a question - please explain item #5. Is this referring to the threaded pushrod between the M/C and booster ??
        • Harry S.
          • July 31, 2002
          • 5295
          #19
          Yes, I need to recess the pin. Everything expands when it get hot and the pedal comes up.
          • Dave S.
            • August 31, 1992
            • 2924
            #20
            Harry,
            You need to hope the lock down lasts for a while longer. Seems your list is growing and you still have another car to get to.
            • Harry S.
              • July 31, 2002
              • 5295
              #21
              Harry,
              Yep, one item I forgot to mention. I had the driveshaft balanced over the winter with a new 16 spline slip yoke and that seems to have fixed my ongoing vibration problem. I'll re-balance the wheels and tires next week.
              • Dan B.
                • July 13, 2011
                • 545
                #22
                26* here this AM with the wind, cold start choke goes to the top of the list.
                • Michael J.
                  • January 27, 2009
                  • 7121
                  #23
                  I have been driving mine lately more than usual, and found the left front upper A arm bolt and washers laying in my driveway as I returned from a trip driving my '66. I checked all my C2s and 1/2 of them had very loose upper A arm bolts, so always a good idea for check them, they seem to come loose often and it is almost impossible to get a torque wrench on them. The lower ones, it seems, never get loose as you can torque them down easy.
