63 Storage heartburn - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5295
    Just posting to have everyone in the north check their cars when stored for months over the winter.
    I finally got under my 63 that has been up on the lift since November. Not pleased.
    1. Gas on the underside of the fuel pump, so after many hours a new pump was installed.
    2. While working on the pump I noticed a leaking rear wheel cylinder, so after hours a new wheel cylinder was installed.
    3. While working on the wheel cylinder I noticed a trailing arm shim fell out, so after some time I repaired the shims.
    I can't wait for my first ride to see what else has failed.
    Just an FYI, check your cars close after storage.
    Love this hobby.
  • Michael G.
    • November 12, 2008
    • 2157
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • Owen L.
      • September 30, 1991
      • 868
      Re: 63 Storage heartburn
      How in the world does a trailing arm shim fall out? To where had it fallen? And what does storage have to do with it?
      • Michael G.
        • November 12, 2008
        • 2157
        63s have unique trailing arm shims. They are not held to the vehicle by anything but luck. Essentially designed to fall out. I need some now. As a matter of fact, all 63 s can be followed through the forest by the trail of trailing arm shims they leave in their wake.
        Mike
        • Dave S.
          • August 31, 1992
          • 2924
          Love this hobby.
          Harry,
          Did the oil pan project get put on the back burner.? Or do you need a rest.?
          • Harry S.
            • July 31, 2002
            • 5295
            Harry,
            Dave, the oil pan is for the other car.
            • Jimmy G.
              • November 1, 1979
              • 976
              Harry
              Put a set of snow chains on it and drive it year round. LOL One of the advantages of living in the south is that we can drive year round.
              • Michael G.
                • November 12, 2008
                • 2157
                You need an oil pan, Harry?
                Mike
                • Harry S.
                  • July 31, 2002
                  • 5295
                  Mike, Thanks for asking, but I located an original in perfect shape. I'll put it in when I replace the rear main seal. Hopefully this week.
                  I'm getting the garage floor done and I need to stop the leak.
                  • Joe R.
                    • July 31, 1976
                    • 4550
                    Harry,
                    I have several 63 trailing arm shims and would like to know how to detect they are broken before I go trying to repair them? Don't want to ruin a very rare 63 unique part! Thanks!
                    Please supply a pic of the broken one please!
                    JR
                    • Harry S.
                      • July 31, 2002
                      • 5295
                      Originally posted by Joe Ray (1011)
                      Harry,
                      JR
                      JR, it did not break. It just fell out. I put it back in and tightened everything up again.
                      • Frank D.
                        • December 27, 2007
                        • 2703
                        It is my understanding that original 63 T/A shims are not slotted and the trailing arm front bushing bolt goes through a hole in them (which makes rear alignment troublesome) and they shouldn't ever fall out.....the later slotted shims not so much.... Is this wrong ?
                        My 63 came to me with incorrect slotted shims but they were well tucked down into the frame cavity and even when the poly bushing some owner put in blew apart I didn't lose any...
                        • Harry S.
                          • July 31, 2002
                          • 5295
                          Please look at post 28 in this thread ----> https://www.forums.ncrs.org/showthre...ght=1963+shims
                          • Joe R.
                            • July 31, 1976
                            • 4550
                            Frank,
                            1963 trailing arm shims were slotted originally. There was even a TO showing how to drill and install a pin to keep them from coming out. The pin went thru the frame but later the shims only had a hole for the bolt to prevent them from falling out while enjoying the ride.
                            JR
                            • Frank D.
                              • December 27, 2007
                              • 2703
                              Frank,
                              JR
                              Yeah Joe - I seem to remember that from the dim past...
                              Thanks for stimulating the ole brain cells again...
