68 L71 Center Carb Base Gasket - NCRS Discussion Boards
  • Michael B.
    • June 18, 2007
    • 400
    Re: 68 L71 Center Carb Base Gasket
    You can not use the standard Holley 2300 base gaskets for our Tri-Power applications. Using a standard gasket or installing a gasket upside down will indeed result in a vacuum leak. These photos will clearly show the problem with the PCV port. Good news is that the 3 gaskets set should be available from virtually all the Corvette online suppliers.
    • Rich G.
      • August 31, 2002
      • 1403
      Thanks Mike.
      We we do have the correct shape gasket to cover that port. It may be the carb is slightly warped and needs a more compressible gasket.
      The trouble is all the suppliers offer the same Felpro gaskets which are not acceptable.
      • Leif A.
        • August 31, 1997
        • 3646
        Originally posted by Rich Giannotti (38594)
        Thanks Mike.
        Have you thought about doubling down on the gaskets to give you more compression? Just a thought.
        Leif
        • Rich G.
          • August 31, 2002
          • 1403
          • Danny P.
            • Today
            Holley Carb kit 37-396 work perfect for my Tri-power set up and passes NCRS judging with no problem and it not a Repro. part
            • Rich G.
              • August 31, 2002
              • 1403
              • Daniel S.
                • February 1, 2000
                • 164
                The only issue I see with the Holley 37-396 kit is the bowl to main body gasket is blue in color. Ordered 3 last week and they are all like that.
                • Danny P.
                  • Today
                  Holley have all kinds black main body and bowel gaskets they come in a pack of 4 the kits does come with blue one but if your NCRS judging the car just order a pack of 4 Black gaskets you would need 3 anyways everything else in the kit is all factory stock
                  • Mark G.
                    • January 31, 2007
                    • 177
                    #24
                    The top gaskets are from the Doc, and the bottom ones are over the counter GM gaskets I bought many years ago. The Docs match the GM is size and shape and have the same smooth, slippery feeling as the GM ones. They are a bit thicker than GM's- 0.031" cs 0.058" and are a lighter colored material.
                    • Danny P.
                      • Today
                      #25
                      There exactly like the Holley 37-396
                      • Rich G.
                        • August 31, 2002
                        • 1403
                        #26
                        • John M.
                          • January 1, 1998
                          • 813
                          #27
                          • Rich G.
                            • August 31, 2002
                            • 1403
                            #28
                            • John M.
                              • January 1, 1998
                              • 813
                              #29
                                • 15621
                                #30
                                Originally posted by John McRae (30025)
                                Rich, there’s got to be something wrong with those mating surfaces. I’ve used and reused those thin ones without any problems with vacuum leaks. It must be the carb base or the manifold itself. I would say that you should confirm that first. Good luck; aren’t tripower fun?
                                Yes, they are.
                                John
                                I can only offer sage advice, which I am sure you will not welcome: “The only thing worse than one Holley is three Holleys"
                                Verifying the root cause of your issue is a good path to take. Best of luck to you.
                                Last edited by Terry M.; August 19, 2018, 03:28 PM. Reason: spelling before Patrick gets to it
