68 L71 Center Carb Base Gasket - NCRS Discussion Boards
  • Danny P.
    • Today
    #31
    Re: 68 L71 Center Carb Base Gasket
    Best tool is a flat aluminum file , check for warped main meter body and metering plates and base plate, the Holley kit 37-396 are the perfect base gasket passes NCRS judging at Nationals, don,t know what the big fuss is about on the base Gasket it in the Holley kit , if your looking for the very thin Black paper Base Gasket good luck finding those, try a swap meet you may get lucky , Tri-Power setup are very simple Carbs to work on been doing them for over 30 years
      • 43221
      #32
      All-----
      The 1967 part number for the gaskets was GM #3902372. For 1968-69 and 1967 SERVICE after 1967 the part number was GM #3921932. The latter was discontinued more than 35 years ago so NOS might be hard-to-find.
      Do I have any of these for reference purposes? Nope, I do not. I don't have ANY parts which were part of 3X2 systems, N-14 side exhaust systems, or TJ-2 louver trim. Never had any and never going to have any.
      • Danny P.
        • Today
        #33
        • John M.
          • January 1, 1998
          • 813
          #34
          • Danny P.
            • Today
            #35
            thank you John
            • Rich G.
              • August 31, 2002
              • 1397
              #36
              • John M.
                • January 1, 1998
                • 813
                #37
                Always good to hear the solution.
                Thanks Rich
