Appreciate the advice . All my original glass is intact. I don't want a OOP'S moment here. Thanks again !
Installing the side window glass back in to Window Channel
I wanted to double check with you guys regarding installing the glass back in to my side window channel. I have the new rubber grips as you can see. Directions from LIC say to place glass on end & tap the track back on. So, am I going to hold this window vertically & then slide this track with new rubber "DOWN" over the glass, or place this where it should be on the bottom of glass & then tap it on as a whole going into the track. My thoughts were to use some soapy water as well.
Appreciate the advice . All my original glass is intact. I don't want a OOP'S moment here. Thanks again !Tags: None- Top
Re: Installing the side window glass back in to Window Channel
I just finished up installing the power window motor & arms in conjunction with the front vent window assembly. Doing this is REALLY not TOO tough if you take your time , but getting that vent window in a coupe without scratching any paint---------------UGGGGGG. LOL.- Top
Fred,
I guess I should have made those measurements before I removed my glass...
Gary- Top
Gary, my apologies. 86 my last post--the measurements I gave were the remaining rubber left in my right side channel before cleaning.
See below---I double checked my left side ( still intact) we have 3/8" Glass overlap from stainless & 1/2" glass overlap rear. This should be darn close .- Top
The attached is an article I saved several years ago. I followed the dimensions on the sketch (page 2) when I re-set my windows and I was very happy with the results.Attached Files- Top
The original glass setting tape was a composite of rubber and cork. I recently re-set all the side glass in my 65 using the same product, available at most glass shops. It requires using a petroleum product to make it swell and securely grip the glass.- Top
