Installing the side window glass back in to Window Channel - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7019
    Re: Installing the side window glass back in to Window Channel
    Originally posted by Jim Durham (8797)
    The original glass setting tape was a composite of rubber and cork. I recently re-set all the side glass in my 65 using the same product, available at most glass shops. It requires using a petroleum product to make it swell and securely grip the glass.
    Jim,
    Can the rubber/cork product be bought online? What is the petroleum product you used?
    Gary
    • Jim D.
      • 2884
      Gary, I went to the local glass shop and picked it up but I'm sure you can get it online. Once assembled, I sprayed it with WD40 and the next day it was tight as a drum. The guy I dealt with at the glass shop explained how it was done in "the old days" but they now use a urethane compound to set glass but keep the old stuff around for us "purists".
      • Gary B.
        • February 1, 1997
        • 7019
        #18
        Jim,
        I found this rubber-cork glazing compound on Amazon. It's brown. Was the original GM stuff black?
        https://www.amazon.com/GASKET-TAPE-R...azing+compound
        Gary
        • Jim D.
          • 2884
          #19
          Gary, I would think any glass shop would have it but there are several sellers on E-Bay (including Ekler's) that have it listed. Do a search for "glass setting tape". You have to be careful to get the correct thickness as it comes in 1/64" increments. I used the 1/32" thickness for the side windows. Here's a pic. showing what I used. The black, shiny side goes against the glass.
