Installing the side window glass back in to Window Channel - NCRS Discussion Boards
  • Fred Y.
    • April 30, 2000
    • 319
    I wanted to double check with you guys regarding installing the glass back in to my side window channel. I have the new rubber grips as you can see. Directions from LIC say to place glass on end & tap the track back on. So, am I going to hold this window vertically & then slide this track with new rubber "DOWN" over the glass, or place this where it should be on the bottom of glass & then tap it on as a whole going into the track. My thoughts were to use some soapy water as well.
    Appreciate the advice . All my original glass is intact. I don't want a OOP'S moment here. Thanks again !
  • Russ S.
    • April 30, 1982
    • 2162
    Re: Installing the side window glass back in to Window Channel
    Definitely use soapy water or you will likely tear the rubber.
    • Fred Y.
      • April 30, 2000
      • 319
      Absolutelty Russ, how have you gone about "sliding" that channel on may I ask ?
      • Russ S.
        • April 30, 1982
        • 2162
        I set the glass on edge (top down) and then set the rail over the glass and just tap it down onto the glass. It goes pretty easy.
        • Fred Y.
          • April 30, 2000
          • 319
          Ok ,that was what I was trying to get out of this. I'll use my rubber hammer & move it down slowly a little bit at a time. Thank you.
          • Gary B.
            • February 1, 1997
            • 7040
            Does anyone know how exact you have to be in position of the glass relative to the two ends of the channel?
            Gary
            • Fred Y.
              • April 30, 2000
              • 319
              Gary the front leading edge of the glass was 3/8" away from the LE of the stainless. The rear of the window was 1 1/8" away from the trailing end of the stainless.
              • Fred Y.
                • April 30, 2000
                • 319
                I just finished up installing the power window motor & arms in conjunction with the front vent window assembly. Doing this is REALLY not TOO tough if you take your time , but getting that vent window in a coupe without scratching any paint---------------UGGGGGG. LOL.
                • Gary B.
                  • February 1, 1997
                  • 7040
                  Fred,
                  I guess I should have made those measurements before I removed my glass...
                  Gary
                  • Fred Y.
                    • April 30, 2000
                    • 319
                    Gary, my apologies. 86 my last post--the measurements I gave were the remaining rubber left in my right side channel before cleaning.
                    See below---I double checked my left side ( still intact) we have 3/8" Glass overlap from stainless & 1/2" glass overlap rear. This should be darn close .
                    • Russ S.
                      • April 30, 1982
                      • 2162
                      Gary, It isn't critical. In the past I have centered the glass in the track.
                      Gary
                      • Gary B.
                        • February 1, 1997
                        • 7040
                        Russ,
                        Thanks. That makes me feel better.
                        Gary
                        • Michael M.
                          • February 7, 2011
                          • 186
                          The attached is an article I saved several years ago. I followed the dimensions on the sketch (page 2) when I re-set my windows and I was very happy with the results.
                          • Gary B.
                            • February 1, 1997
                            • 7040
                            Thanks Mike.
                            Gary
                            • Jim D.
                              • 2884
                              The original glass setting tape was a composite of rubber and cork. I recently re-set all the side glass in my 65 using the same product, available at most glass shops. It requires using a petroleum product to make it swell and securely grip the glass.
