Corvette Owner's Pin Survey - 2018 Update - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1922
    Re: Corvette Owner's Pin Survey - 2018 Update
    Originally posted by Richard Thomas (2276)
    Interesting subject. I have five of these pins. One came with my 62 when I bought it over 40 years ago and the other four I picked up over the years. One of the five is the early type (56 to 60) and the other four the later. My early pin is stamped "GBM & Co" with "10K" below and a third line "CINTI.O . Not sure what the third line means, could be Cincinnati Ohio. I don't think my pictures are good enough to read the back stamping.
    Yes, the last line is CINTI.O. and stands for Cincinnati, Ohio. That was the home for Gordon B. Miller. Here is a different type of pin made by Miller with the same marking.
    • Edward M.
      • November 1, 1985
      • 1922
      Originally posted by Joe Maulsby (17166)
      I know the 10k DP means 10 karat double plate (means gold plated on both sides). What does the M 1/5 mean? Did all of the owner pins have white enamel background?
      The M 1/5 10KDP puzzled me for a while. Then I started looked at jewelry marking and figured it out.
      The M is, I suspect, for Miller (as in GBM - Gordon B. Miller). That is just a guess
      The 1/5 = 20%. 20% of the weight of the object is gold.
      10 KDP is, as you indicated, 10 karat double plate
      FYI: From one of the jewelry sites.
      1/20 12K - What is that??
      The first numbers (1/20) indicate the ratio between the mass of the Karat Gold sheet to the mass of the entire piece (karat + base metal) at any given dimensions of the Gold filled sheet.
      Clarification: Surface area does not play a part for calculating Gold Filled value. Whatever size or shape you cut the Gold Filled sheet, the ratio by mass remains the same.
      The second number indicates the karatage of the Gold sheet alloy.
      Now, say we want to know how much actual gold is there in a sheet of Gold Filled.
      Example:
      How much gold would there be in a 100g stamped sheet of "1/20 12K" Gold filled?
      1/20 = 0.05 (or 5%) 100g x 0.05 = 5g
      12K = 12/24 = 0.5 (or 50%)
      5g x 0.5 = 2.5g
      The answer will be: 2.5g of pure gold.
      These are the exact steps our calculator
      • Keith W.
        • June 30, 1998
        • 375
        Here's my owners pin and patch for my 65 - I can make out the 10k
        • Ray K.
          • July 31, 1985
          • 375
          All this information made me curious -- so I had to go find my '65 owners pin. It is stamped with MI 5 along with many others. The letter, pin, and the patch are still intact. I wore the plastic identification card out because I carried it with me for many years.
          Ray
          • Edward M.
            • November 1, 1985
            • 1922
            So, would an owner's pin that had the M 1/5 10KDP marking be considered incorrect / service replacement for a 1960 and earlier Corvette.
            • Edward M.
              • November 1, 1985
              • 1922
              OK boys and girls;
              I got a suggestion from a friend that this information about owner's pins (and perhaps the associated tie tacs) might make an interesting article for The Restorer?
              What do ya'll think?
              I am happy to do it if there is some interest in it, and I can find enough good info and pictures about it.
              I no longer own any of the pins, so I would need some assistance with good photos.
              Thoughts?
              Ed
              • Keith W.
                • June 30, 1998
                • 375
                [QUOTE=Edward McComas (9316);822571]OK boys and girls;
                Thoughts?
                Ed - would be good to get an updated definitive list / pictures / detail - there must be plenty of Vettes out there with full documentation and pins - all the best in hunting them down - Keith
                • Edward M.
                  • November 1, 1985
                  • 1922
                  It appears that this topic has been well covered in the past...
                  Rev. Mike Ernst had an article entitled "Corvette Owner's Packet" in Volume 5, #4 (Spring 1979) issue of The Restorer.
                  Alan L. Severson has an article entitled "1957 - 1973 Corvette Owner Kits" in Volume 12, #4 (Spring 1986) issue of The Restorer.
                  Both articles are in depth, well researched, and provide a wealth of information about this topic.
                  I don't see any value in another article about Corvette Owner's Pins / Kits, Gordon B. Miller accessories as I have no additional information to provide.
                  • Vinnie P.
                    Editor NCRS Restorer Magazine
                    • May 31, 1990
                    • 1573
                    #24
                    Ed...it's your call, but when you think about it, take into consideration that over 70% of our membership as it now stands was not here in 1986 when the last article was published! Just food for thought...
                    Vinnie
                    • Edward M.
                      • November 1, 1985
                      • 1922
                      #25
                      Vinnie
                      10-4 Vinnie. I think it would be a good article, but I would have to borrow all of the pictures.
                      Mu interest was in the differences in the back markings, and whet they meant.
                      I'll think about it.
                      Ed
