63 Stamp pad - NCRS Discussion Boards
63 Stamp pad
  • Timothy B.
    • April 30, 1983
    • 5186
    Re: 63 Stamp pad
    Originally posted by Gene Manno (8571)
    Your pad looks good. Don’t do anything to it other than dab a bit of motor oil on it to retain what you have. Seriously.
    I agree with Gene 100%, dab some oil on it and leave it alone. What else are you going to do, the sanding has scratched the pad so the machine marks are pretty much gone but to me it looks like the real deal stamping.
      • 11644
      Re: 63 Stamp pad
      Originally posted by Patrick Boyd (9110)
      I think you can see the grain on the deck surface that was under the head. You can also see it continue slightly into the cleaned up area of the exposed pad, but the outermost part of the pad is too pitted and then scrubbed to retain the grain. A lot of blocks including most big blocks have pretty smooth grain to begin with.
      Agreed.
      There are broach marks there, but they're faint.
      And, that's OK.
      Yes, someone put scratch marks in there too, which is too bad, but such is life.
      • Michael G.
        • November 12, 2008
        • 2157
        #18
        Re: 63 Stamp pad
        The marks in the first pic are clearer.
        The broach marks on the pad of my original engine 63, VIN 3922 look a lot like those, i.e. very faint, almost invisible to the naked eye, but very clear when you shine a light along the edge of the block surface. Never had point deducted for the pad, through two Duntovs. Since VINs of this car and mine aren't that far apart, it makes sense that its 327 would have faint marks also... I'd say they're likely real...
        Mike
        1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
        1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
