carb date code range for 66 - NCRS Discussion Boards
+ More Options
Posts
  • Kevin B.
    • June 30, 2004
    • 36
    I am in need of either a major restoration on my 4160 list 3367, p/n 3884505 DA, date coded 2429. My car's birthdate is November 24, 1965. Based on the date code I am confident that unless the "9" was inadvertently put in to the punch upside down, this carb belongs to 1969. Given that info and my need for a decent rebuild - I was going to go with Eric at VintageCarMuscleParts.com for a complete resurfacing and refinishing. However, given the cost involved I'm wondering if it would be more advantageous to just get a new list 3367 w/o any date code. This way I get a new throttle body with mating surfaces that fit tight all around. The carb I have now - coded 2429 - came with my car when I picked it up in '98.
    If I could find a carb that was possibly made for my car what date code / range would I be looking for? Ideas, suggestions?
    vin: 194676S106735
    327, L79
  • Joe R.
    • May 31, 2006
    • 1822
    Re: carb date code range for 66
    Hi Kevin,
    I would look for a carb dated a month or two before the engine assy date if it were my car. But anything up to six months prior will pass NCRS judging.
    Joe
    • Gary B.
      • February 1, 1997
      • 7074
      Kevin,
      I'm pretty sure that the 4-digit date code on your carb is indicative of a later service replacement. The original 3367 carb on my July build date '66 is 661.
      Gary
      • Kevin B.
        • June 30, 2004
        • 36
        So, just to clarify..your car's birthday is in July '66 and is your carb the original for the car? It would seem that a carb date code 661 would need to be at the lower range of my car, since mine has a November birthday.
        Thanks for the info, Gary.
        • Gary B.
          • February 1, 1997
          • 7074
          Kevin,
          The code 661 mean 1966, June, 1st week, which makes perfect sense for a '66 with a July '66 build date. I take it you don't have the '66 TIM&JG? The carb date code info is spelled out there very clearly on page 103. And example carb date for your Nov car might be 501, for 1965, October, 1st week. I don't know if 501 is a common date code, I just made up that example. Holley carbs of that era were made in batches, so some date codes are much more common than others.
          Gary
          • Kevin B.
            • June 30, 2004
            • 36
            No, I don't have the '66 TIM & JG but it will become part of my library soon enough. Thanks for pointing to me in the right direction. Your info was quite useful.
