1967 Soft top rear window - NCRS Discussion Boards
  • Jim S.
    • March 1, 1986
    • 1398
    Re: 1967 Soft top rear window - Update
    Greg ,
    The Meguiars products work even better on a hard top as you can really bear down on the plexiglass window.
    • Donald O.
      • May 31, 1990
      • 1585
      Cleaning
      I used a new "microfiber towel" (damp) and rubbed it in 6" circles, then wiped clean with a nice soft cotton bath towel. I did the outside of the widow first with the top latched down in the back and loosely attached in the front. The big purple bath towel was for protection and a place to put the towel or mf-towel. After completing the outside I did the inside by opening the top at the rear and folding it onto the purple towel. I think I flipped it open and closed 3 or 4 times until I was satisfied all streaks, smears, dirt, and hazed were gone from both sides.
      Polishing
      I used another new "microfiber towel" (damp) and rubbed it in 6" circles, then wiped clean with another nice soft cotton bath towel. I did the outside of the widow first with the top latched down in the back and loosely attached in the front. The big purple bath towel was for protection and a place to put the towel or mf-towel. After completing the outside I did the inside by opening the top at the rear and folding it onto the purple towel. I think I flipped it open and closed 3 or 4 times until I was satisfied.
      The hardest part was getting right to the four edges of the clear and trying not to go onto the white. I probably could have set the heat in my garage lower as I was in a Tee shirt and actually sweating when I was done with either stage.
      I will have to replace the top though. If you look real close in the before picture, you'll see how it is de-bonding from the top itself and there is actually a small hole. About the size of a pencil diameter.
      But the rear window came out pretty darn good IMHO
      Don
