1967 Soft top rear window - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1593
    About 25 years ago I replaced the soft top and all was well. The old top was worn beyond repair and I couldn't see out the rear window. Well this new now old top is in good shape still as is the weatherstrips, but the rear window is getting to the point that it is no longer a window.
    Can the plastic rear window be saved or is a new soft top in my immediate future again.
    If it can be saved, what products and how to use them?
    Don
  • Leif A.
    • August 31, 1997
    • 3646
    Re: 1967 Soft top rear window
    Don,
    Great article here and I'm a firm believer in Meguiar's products.
    Nothing looks worse than a convertible tops plastic rear window that you can''t see out of. Proper care and maintenance will insure you can see out.
    Leif
    • Bob W.
      • December 1, 1977
      • 802
      Don If you try the Meguiar's Products on your top let us know how it work's out.
      Bob
      • Greg H.
        • 105
        Hi Leif,
        Wonderful article. Thanks for your help!
        Greg
        • Donald O.
          • May 31, 1990
          • 1593
          I'll pick up some of the Meguiar's and report back this weekend.
          Thanks for the help.
          Don
          • Donald O.
            • May 31, 1990
            • 1593
            Re: 1967 Soft top rear window - Update
            Don
            I had to order the Meguiar's from O'reilly's on Friday. They had them on clearance for only $0.88 each. They finally came in and picked them up today.
            Gosh.....time for a nap
            I'll get to it tomorrow.
            Don
            • Donald O.
              • May 31, 1990
              • 1593
              Got to be in the garage and start on the top's rear window.
              It was very opaque and dirty, although it felt very clean and smooth.
              A close up of the date stamping
              After the cleaning with the Meguiars #17 Cleaner
              I tried following the directions in the posted link above by Leif Anderson on how to use it but found that it gave some pretty crappy results. They suggest to do the whole window and allow to dry then buff to a shine. I found it to be extremely difficult to buff and remove. What worked for me was to apply and while still damp buff to a shine.
              Tomorrow I'll apply the Meguiars #10 polishing compound and post those results.
              Don
              • Ralph E.
                • February 1, 2002
                • 905
                Looking Good!
                Tried Meguiar's on my friends 66 GTO, made a big difference.
                • Peter M.
                  • May 30, 2013
                  • 359
                  Hi Don,
                  I have never used the #17 cleaner, however I have used the #10 polish and always had excellent results. I have not ever used it on a convertible back window though.
                  It looks like you have had good results with the cleaner. That looks like a really nice car with a very pretty color combination.
                  Kind Regards,
                  Pete
                  • Donald O.
                    • May 31, 1990
                    • 1593
                    Re: 1967 Soft top rear window - Final Update
                    Used the polish today, much, much easier to use than the cleaner.
                    I think it turned fairly well.
                    Don
                    • Donald O.
                      • May 31, 1990
                      • 1593
                      Originally posted by Peter Miller (58508)
                      Hi Don,
                      Kind Regards,
                      Pete
                      Thanks for the compliment Pete.
                      Don
                      • Leif A.
                        • August 31, 1997
                        • 3646
                        Don,
                        That looks brand new!! Glad the Meguiars worked out.
                        Leif
                        • Ralph E.
                          • February 1, 2002
                          • 905
                          Don, with the results you've shown may I suggest you explain, so as to help others, how you applied the cleaner and the polish. Type of applicator, difficulty of process etcโ€ฆ..
                          Your rear window looks incredible!
                          • Greg W.
                            • February 26, 2015
                            • 141
                            Don, The window looks great, Did you only do the outside or the inside as well. Also would this work on a hard top rear window???
                            Greg
                            • Leif A.
                              • August 31, 1997
                              • 3646
                              Don
                              Don,
                              The article actually says to do a 5"x 5" section at a time for just the reasons you expressed. Letting that stuff dry on there is a major faux pas. Glad that everything turned out well in the end. The result of your efforts are undeniable.
                              Leif
