1967 - Air Conditioning Heater Vacuum Switch On Box - Brass - NCRS Discussion Boards
  • Bill C.
    • July 15, 2007
    • 904
    hey ...
    does anyone know where I can a replacement brass vacuum switch for my AC 67?
    One that mounts on top of the heater box.
    All I can find is some aftermarket plastic junk.
    Can mine by rebuilt?
    Thanks in advance.
    Bill
  • Mike M.
    • May 31, 1974
    • 8400
    Re: 1967 - Air Conditioning Heater Vacuum Switch On Box - Brass
    i think page campbell can rebuilf yours . he's an ncrs member. post here often. mike
    • Bill C.
      • July 15, 2007
      • 904
      Mike -
      many thanks.
      I will find him and send a PM..
      Have a great weekend.
      Bill
      • Wayne M.
        • March 1, 1980
        • 6414
        Believe Dr. Rebuild also has something on his website about replacing the rubber O-rings. Here's the one on my (ex) '65.
        • Larry M.
          • January 1, 1992
          • 2700
          Both DR REBUILD catalog (and possibly website) and the Corvette Forum C1/C2 Section have detailed instructions on how to rebuild. I participated in the CF Section rebuild thread. If you can't locate it, I can provide date and title to help you find it. Included is the o-rings to use in the rebuild as well as how to remove and disassemble the switch.
          LICS used to sell brass reproductions. I bought an extra for myself just in case. You may try getting the GM part number and then searching thru internet (incl Ebay) and various GM Dealers Parts Network. Every now and then I see a new one (NOS or LICS reproduction) come up for sale.
          Larry
          • Bill C.
            • July 15, 2007
            • 904
            Larry -
            I found the thread on the CF.
            I have taken my valve part, and cleaned it all up.n It had a rubber hose looking sleeve over the piston. It was about 1/2" in length
            but it was all dry rotted and cracking. the sleeve was much wider than the .092 section on the piston.
            Will get the O-rings Monday from Grainger and re-assemble.
            Thanks to all for the info and tech leads.
            The valve is not so bad too work on.
            MANY THANKS!
            Bill
            • William F.
              • June 9, 2009
              • 1364
              Back to original question. Doesn't some vendor, Paragon, Long Island Corvette, etc. carry brass reproductions? Being plastic aside, do the plastic ones function properly?
              • Bill C.
                • July 15, 2007
                • 904
                from what i could gather the brass one is not made any longer.
                the plastic one works but is a real POC.
                the plastic is very brittle and is prone to cracking.
                I was installing the repro on the heater box and while putting on the larger vacuum hose cracked off the plastic nipple end.
                --- the heater box was out of the car so tight quarters was not an issue.
                • Larry M.
                  • January 1, 1992
                  • 2700
                  Answered in Post #5.
                  Larry
                  • Kim C.
                    we no longer make the Brass switch -- see #36-31 for plastic/metal hybrid that is now available.
                    photo on website. (not 'our' repro)
                    LIC
                    • Bill C.
                      • July 15, 2007
                      • 904
                      just an FYI ..
                      picked up the o-rings today.
                      did some cleaning and installed them with proper lube.
                      switch works like a champ!!
                      just an aside note.
                      i installed an additional O-ring in the end cap (between the spring and cap).
                      It helps center the rod and also seals the end cap and makes zero vacuum leakage.
                      This is the best technical board I have ever been part of !!!
                      Thanks to all...
                      Bill
                      • Larry M.
                        • January 1, 1992
                        • 2700
                        Originally posted by Bill Chamberlain (47576)
                        just an FYI ..
                        just an aside note.
                        Thanks to all...
                        Bill
                        Bill:
                        Glad for your success.
                        Larry
                        • William F.
                          • June 9, 2009
                          • 1364
                          Larry,
                          Can you send the CF thread or tell me what to put in for "search"?
                          • Larry M.
                            • January 1, 1992
                            • 2700
                            Larry,
                            Bill:
                            You asked for it.
                            C1 & C2 Corvettes - Have You Seen the Inside of a C-60 A/C Vacuum Valve . . . . ??? - UPDATED: Post #16 below details the repair for this item. . . . and if so, are you able to tell me what's missing from this one? This is the original A/C vacuum valve which mounts on top of the inside heater housing on a factory air...
                            Larry
                            • William F.
                              • June 9, 2009
                              • 1364
                              Larry,
                              Thanks for sending location of CF post about rebuilding vacuum switch. However, I'm confused about which end of housing to straighten crimps. He says " side opposite button" but does he mean side adjacent to button or does he really mean the side of the box fartherest away from button?
