Halfshaft flange finish - NCRS Discussion Boards
  • Alan D.
    • January 1, 2005
    • 2053
    Re: Halfshaft flange finish
    Here is an example of the long line, a little hard to see (original 63 shaft, just cleaned)
    • Joe C.
      • August 31, 1999
      • 4598
      Very true Gene. The welded tube finish cannot be reproduced. The only way is to re-use the forged yokes with a new tube welded between.
        • 43279
        #18
        Joe-----
        Yup, they call it "re-tubing". In addition, even the original as-forged finish of the yoke ends is impossible to restore as it originally appeared.
        However, as Doug pointed out, if one has a big block, the half shafts were shot-peened. This finish is easy to restore. Just have them re-shot-peened with correct size shot. Some LT-1's may have also used the shot-peened half shafts.
