Halfshaft flange finish - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1416
    Guys,
    What is the finish of the halfshaft flanges on a '69? Finally getting ready to start assembly of the rear suspension and just need to know this. Thanks.
    Mike
  • Joe C.
    • August 31, 1999
    • 4598
    Re: Halfshaft flange finish
    Originally posted by Michael Leonard (46610)
    Guys,
    Mike
    Natural blue/gray color of forged steel.
    • Anthony D.
      • August 31, 2005
      • 110
      Any pointers on how to get the finish?
        • 43277
        Anthony-------
        It's virtually impossible to replicate in any way that would not be easily detectable.
        • Joe C.
          • August 31, 1999
          • 4598
          You'll get multiple suggestions for this.
          Hopefully the u-joints are not yet installed. Use a wire wheel and Naval Jelly to remove any rust. This should restore a natural finish. DO NOT media blast with sand. It can probably be tumbled or media blasted with walnut shells or something similar. Once cleaned, coat with WD40. I like to coat with satin clear-coat, but many here will "poo-poo" this approach.
          I would think that Quanta still "restores" drive/half shafts. They get the forgings correct, but polish the steel tubes, which are a far cry from the original sheet steel finish. They also neglect to duplicate the bluish weld discoloration on the seam and the butt welds on the ends.
          • Douglas L.
            • May 8, 2015
            • 181
            Just to add a bit on the shaft finish. All BB cars got halfshafts that were shot peened. Not sure but I'd imagine that the weld discoloration would be at least partially in not completely obliterated by the process. A machine like a wheel-a-brator would replicate this nicely.
            • Gary J.
              • April 1, 1980
              • 1246
              Quanta is not doing half shafts or drive shifts, the vender they were farming this out to passed away from what I understand.
              • Jeff P.
                • 799
                Did my 68 shafts this way.
                68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
                2014 Arctic White Z51 Vert. (Wifes)
                • Gary J.
                  • April 1, 1980
                  • 1246
                  What was the process?
                  • Jeff P.
                    • 799
                    Sorry for the late response,I'm at Carlisle. Glass beaded the ends had the rolled steel polished by a local co. Then had a friend,member use a propaine torch to blue the welds. He suggested propaine because its temptress is lower.
                    • Gary J.
                      • April 1, 1980
                      • 1246
                      What is the company that did the polishing?
                      • Jeff P.
                        • 799
                        I can locate the receipt , I believe it was Spencer , Ma.
                        • Gene M.
                          • April 1, 1985
                          • 4233
                          The originals were a drawn welded tube and were not polished. Also the draw lines are longitudinal with the length parallel with the weld seam. Very pretty in the photo but not correct.
                          • Jeff P.
                            • 799
                            Great info Gene. Would you have a photo of one.
                              • 43277
                              Gene------
                              I didn't want to be the first to say so, but I agree. These shafts look beautiful but they never originally appeared like this---never.
