What is correct part for 63/64 ignition switch - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5295
    Re: What is correct part for 63/64 ignition switch
    Originally posted by Larry Meyer (37196)
    I have a line on a used one which is why I asked about other models above. But this question. To remove a lock cylinder when you don't have the correct key, isn't i't true that any key for that model of car will allow you to remove the lock cylinder? Does anyone know? Isn't it just a matter of finding and depressing the pin and rotating the cyliner?
    Larry, you can't access the pin until you rotate the tumbler to ACC. You can't get to ACC unless you have the correct key. Therefore, in order to remove it you need the correct key.
    I just went to the garage and verified how it works.
    If it's the used one with a lock cylinder and no key, take it to a locksmith.
    • Peter L.
      • May 31, 1983
      • 1930
      Larry - If I remember correctly, the 1116650 Delco-Remy ignition switch was used on some Pontiacs. I will do some checking to confirm. Pete
      • Peter L.
        • May 31, 1983
        • 1930
        Larry - The Delco-Remy p/n D1449, GM p/n 1116650 ignition switch is not for a Pontiac. According to the AC Delco Catalog 1A-91, 1985 the winner is the 1964 Buick (All Exc. Skylark, Special). Pete
        • Joe R.
          • July 31, 1976
          • 4550
          Larry,
          Here's a few pics of a 63 ignition switch and keys.
          Hope you can read the 635 on the switch.
          The 650 will function for both the 63 and 64 so dont pass up on one of those.
          JR
