Re: What is correct part for 63/64 ignition switch
Larry, you can't access the pin until you rotate the tumbler to ACC. You can't get to ACC unless you have the correct key. Therefore, in order to remove it you need the correct key.
I just went to the garage and verified how it works.
If it's the used one with a lock cylinder and no key, take it to a locksmith.
