Repro wiring harness crossed wires - NCRS Discussion Boards
  • Gary B.
    • January 31, 1997
    • 6994
    I seem to recall that it's common knowledge to some people that two wires in one of the C2 wiring harnesses sold by one of the repro companies (LL or M&H) are crossed. I've searched the archives, but can't find what I'm looking for. Does anyone recall such a problem with one of the C2 wiring harnesses from one of the repro vendors that is currently being sold? Or I am mis-remembering things?
    Gary
  • Jim D.
    • 2883
    Re: Repro wiring harness crossed wires
    I replaced every harness in my 65 with ones from M&H and everything was wired correctly.
    • Gary B.
      • January 31, 1997
      • 6994
      Jim,
      Thanks. Good to know. I know that M&H is endorsed in several previous DB postings.
      I seem to recall the crossed wire problem was with a 'Letric Limited harness, but my memory is too vague to recall the specifics.
      Gary
      • Leif A.
        • August 31, 1997
        • 3611
        Originally posted by Gary Beaupre (28818)
        Jim,
        Gary
        Gary,
        Replaced ALL my wiring harnesses within the last two years with LL harness with zero issues...well, one. The ground wire that exits the harness at the voltage regulator is probably an inch short but you can make it stretch to it's proper location under the capacitor.
        Leif
        • Jim S.
          • February 28, 1986
          • 1392
          Gary,
          I recall that as well .
          If memory serves , LL had crossed a few wires in their 3-prong headlight connectors because they faithfully followed a "misprint " in the Factory Wiring Diagram . Even though the original harnesses by Gm were made differently .
          I am sure they have figured it out by now , and corrected the problem , as that was a while back.
          Jim
            • May 31, 1974
            • 8374
            i installed a main harness in a 67 back in the 80's. i got the harness from lactic limited and there were a pair of wires switched. recall the two wires were in the plug that connected to the rear harness behind the left kick panel. mike
            • Jim S.
              • February 28, 1986
              • 1392
              Mike ,
              I don't remember back that far , however I found a post that I think Gary is referring to :
              Re: 65 Headlight Wiring AIM discrepancies
              Originally Posted by John McRae (30025)
              In the 65 AIM there are two diagrams showing the wiring for the headlight harness extensions. UPC12 sheet A10 shows the tan wire in the right socket and the black in the middle. UPC12 sheet D1 shows the tan in the middle and black to the left.
              I have been warned, more than once, by Joe Ciaravino that the 65 AIM is wrong, but would like some help on the wiring of the extensions. Basically, which sheet is correct?
              In the 67 AIM these same two pages, A10 and D1 show the wiring to be the same in both diagrams. (The two harnesses ahead of these connections are not the same.)
              Thanks for any advice.
              John McRae 30025 65FI Convertible
              John -
              The factory wiring diagram was wrong from '63-'66 (although the actual wiring harnesses were made correctly); if you look at the 3-prong connector that plugs onto the back of the headlight, the bottom terminal is always the black wire (ground). That's why the Lectric Limited harnesses "made exactly to factory specifications" were also wrong and didn't work until LL finally figured out the factory diagram was wrong.
              • Gary B.
                • January 31, 1997
                • 6994
                Jim & MIke,
                Thanks for confirming that I didn't dream up this memory. I assume LL has long since corrected this problem.
                Other than possible price differences are there any strong reasons for choosing LL over M&H harnesses? Better phone support? Better authentic cosmetics? Etc.
                Gary
                • Jim S.
                  • February 28, 1986
                  • 1392
                  Gary ,
                  Here is what I and others have said about that .
                  Thread: Which wiring harness / electrical supplier is best?
                  Jim
                  • Gary B.
                    • January 31, 1997
                    • 6994
                    Jim,
                    That's a very interesting discussion.
                    Gary
                    • Paul J.
                      • September 9, 2008
                      • 2091
                      Jim,
                      Gary
                      And also informative.
                      • Joe R.
                        • July 31, 1976
                        • 4549
                        Thru the years I have used M&H for everything that needs wiring and have had no complaints from any customers. They do it once and do it right with all the correct colors, ends and braiding. Nuf said!
                        From the looks of the previous thread M&H was recommended by everybody that responded.
                        JR
